Went poking around Kickstarter a bit, amazing what people will go for. $1500 5W semiconductor laser engraver (Mr. Beam II) that's raised $422K? My 40W CO2 K40 was under $400 (that came in less than a week from ordering), and you could roll your own 5W semi for vastly less than $1500. Sure, Mr. Beam claims to cut 4mm plywood, but it'll take a whole lot of passes.
Despite a claimed 3D printer slowdown, the $300 all metal Trinus has raised $578K, a $100 smartphone based DLP printer, $2.1Mill, the $1200 DLP SLASH, $254K. Common factor seems to be a very slick campaign page.
And Tiko's now saying their accelerometer lost it's hard plastic backing and breaks solder connections when fastened to their bowden tube. Huh? How did all those bowden extruders ever work in the past without an accelerometer. Can't they glue on a tab (there's this great stuff called epoxy) or 3D print a fix if it's so critical? Guess it takes a lot to make a liquifier liquify.
I'm starting to sound like a skeptical grumpy old moose...
And a disclaimer, I supported a Thingybot, but I've got more faith in Matt than slick glossies. Not worried, it doesn't have a liquifier
