by Mooselake » 2015-Mar-Fri-14-Mar
Both of these userIDs come from Vscaler VPN IPs (which means they're hiding where they originate, and it's a strange coincidence they're both using the same VPN company; maybe they're just getting around the firewall at work...), and while applicable to this Other printers subforum aren't all that relevant to Printrbots. This doesn't guarantee they're spammers, and it is an interesting topic, but it does raise some flags. Hope I'm wrong...
Taken from another source I couldn't (re)find quickly, the best way I've found to determine the correct print temperature is to use a single perimeter object (I like this scaled up 2 or 3 times. It's got both 90 degree corners and a large radius curve) that's big enough to not have any small=print cooling problems, slice it with the lowest temperature you think might print, then hand edit the gcode to increase the temperature 5 degrees every 5 mm (or some other consistent layer thickness, but 5's easy to measure). Print, then take a close look at how the different temps look for both bonding and finish quality, and how well the straights, corners, and curve printed. The best looking section is your best print temp. You might need to play around with cooling fan settings depending on the material, although I doubt you'll need a fan for this abs based filament.
Why is cooling the extruder an issue? Is that a Makerbot thing? 190's not an unusual print temp. Flow issues might mean you're printing at too low a temperature and requiring too much feed pressure (for those who don't know MB uses a screw pressing against the filament to to adjust tension). Makergeek recommends 200 to 230 so 190s a bit low. What are you going to use the stuff for? While it's conductive it's not real conductive - they say 10K ohms/cm (wonder if that's really 10K ohms/square?) so you'd be hard pressed to even light an LED through it. Just curious; at first glance it didn't seem all that useful, but I'm often wrong...
Good Luck!
