by orangefurball » 2015-Mar-Fri-17-Mar
Not really an official announcement, but I figured I would share it with PBT first!
Here is the 99% complete Thingystock V2! (Ignore the messy table...)
Some notable changes include
* Magnetic effector - ZERO backlash
* Aluminum bed - Glass breaks, aluminum doesn't
* Auto-calibration WITHOUT the probe! - The alu bed allows me to use the hotend and bed as a probe combo, meaning there is perfect repeatability and no pesky endstops for calibration
* No clips - while clips were great in theory, screws are the better option. Mounting brackets built into the top and bottom frame allow mounting of everything; no clips required!
* RAMPS board now mounts on top - less intrusive and uses less wire
* And a lot more!
I'm really excited for this printer. It still runs on RAMPS, still has the amazing E3D V6, and is still completely open and expandable!
So how does it print? Here is a quick print sample of Makerbot's Laser Cat (Without lasers)
So what's left to do? I just need to get some feet made from rubber - that's it!
What do you guys think?
orangefurball on 2015-Mar-Mon-04-Mar, edited 1 time in total.
Cubify Cube3 & Makerbot Replicator MiniThingybot Delta Printer150x150x200mm circular build volume, high precision open source 3D printer.
http://www.thingybot3d.com
