by Jon Lawrence » 2014-Dec-Fri-09-Dec
Have you tested yet? May I suggest increasing the belt wrap angle for X and Y. If your belt is a little loose you will probably skip a tooth here and there and sudden direction changes.
Otherwise, it looks nice. Are there slotted holes in the mounting feet so you can make very small adjustments to align the axis?
