[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 379: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
Printrbot Talk Forum • View topic - fabrap
fabrap
fabrap
Postby Fabrice974 » 2014-Sep-Sat-07-Sep
hi everyone
with my little smartrap, i was able to make a new bigger printer
the fabrap
printing dimension : 360*360*260mm
source file: search for thing:470058
thanks to regpy,serge and jon Lawrence for inspiration
Fabrice974
fabrap
Re: fabrap
Postby thawkins » 2014-Sep-Sat-08-Sep
Re: fabrap
Postby Fabrice974 » 2014-Sep-Sat-09-Sep
quick vidéo
youtube . com /watch?v=WRug6bQYUvg
Fabrice974
Re: fabrap
Postby Mooselake » 2014-Sep-Sat-10-Sep
Here's the embedded link for you:
Re: fabrap
Postby Fabrice974 » 2014-Nov-Mon-23-Nov
i have a gt2 belt on z axis now
Fabrice974
Re: fabrap
Postby Jon Lawrence » 2014-Nov-Tue-10-Nov
Jon Lawrence
Calibration mode.
Re: fabrap
Postby Fabrice974 » 2014-Nov-Tue-12-Nov
hi john
'i'm a big fan of your work)
great to have you on my post
here is the edrawing file
https://www.dropbox.com/s/mc1elttzq03nb ... 1.exe?dl=0
you will clearly see the counterweight, so the z height won't fall down if power is turn off
i think that belt will remove any z wooble and should improve layer definition
according to joseph calculator , belt definition is 12.5 micron and as i have build a double resolution, i can theorically have 6.25 micron
i'm currently printing all part to build it and will report every printing test in a couple of days
fabrice
Fabrice974
Re: fabrap
Postby killbox » 2014-Nov-Tue-18-Nov
ooo pretty. i'm looking forward to your tests. never seen a belt z before, looks neat. i'm looking to morph my printrbot into something else. this mite be it
Ramps 1.4
LCD
E3D V6
8x8 Hotbed
smoothieboard
killbox
Re: fabrap
Postby Fabrice974 » 2014-Dec-Sat-02-Dec
first test!
http://www.youtube.com/watch?v=9tSjo90_Pxg
x and z movement from 500 to 20000mm/min
no counterweight for the moment, need to find something small and heavy enough!
z belt is definitvely the way to go
will clean the wiring and test some printing soon
Fabrice974
