by RetireeJay » 2014-Jan-Thu-11-Jan
I used to work in industry, where we had robotic actuators. It's true, DC motors can start and stop extremely rapidly, and they can be very powerful. However, the position control now depends absolutely on high-accuracy feedback. For example, I remember a particular system we built with a DC motor controlling an arm position in a feedback loop. Although the system could remain stationary with zero current flowing in the motor's coils, the feedback system was so sensitive that if I tried to push the arm out of position, it felt to my hand as if the arm had been welded in place; it was extremely rigid - and only because the position sensor detected a tiny deviation from setpoint and sent counterbalancing current to the motor to prevent any further motion.
Of course, when you introduce a control loop (sensor plus actuator) you have completely different dynamics than stepper motors. Properly tuned, you can get excellent results - but control loops can be quite unmerciful to those who don't understand them. This technology is not going to migrate easily into the hobbyist build-a-printer-yourself realm.
BTW, DC motors are a totally different animal than AC motors. AC motors gotta move, and their RPM range is relatively limited. DC motors can operate from stationary up to rather high speeds.
