Work continues.
Here are a couple of pictures showing more of the printer.
First we have the extruder setup. The spool is direct fed and the spool holder actually just clips into the handle on the side. Meaning the position could be adjusted forward or backward to fit different size spools. The extruder is 3D printed, but the metal frame is between the motor and the extruder meaning it acts as a heat sink for the extruder and no longer requires active cooling (unlike the Thingystock!). That means less noise and less mechanical parts that could fail down the line.
Next up is the power/USB input. It uses a standard power plug (the model number escapes me, but it's the same kind that desktop PCs use.) and a USB B plug for the USB connection (not required thanks to the LCD).
The RAMPS board is mounted on top where all of the electrical components are, so the only wiring going down to the bottom is the 12v for the RAMPS board and the USB extension. On the Thingystock, there were motor wires, power, and the USB extension going from top to bottom. Th new design saves wiring and has less failure points.
This is my least favorite part of the design. The LCD mount for this prototype is mounted in a printed frame that is attached to the metal housing. In the final version it will be integrated into the white metal frame. It works though
And finally my favorite addition... LEDs! Just a simple strip of white LEDs is at the bottom of the frame. Why the bottom? Because it won't be blocked by the effector/arms while printing. You can see how it lights up an example print (not from the Thingybot) in the picture.
I hate to be a pain but I really appreciate feedback for these. I am the only person designing and building it so I don't have a chance to get a group opinion on it. This really helps!
