Printrbot Talk Forum • View topic - The PrintrNot?
The PrintrNot?
The PrintrNot?
Postby DonaldJ » 2015-Oct-Thu-21-Oct
Under the guidance of our good friend RetireeJay, I was able to complete my CoreXY printer, and here it is (banana & vinyl for scale)...
Clone Rev.D Printrboard, 1st Gen. direct drive aluminum extruder, & Ubis 13 metal hotend, all ABS parts printed on Kickstarter edition of the PB+.
If you don't mind about 150 hours of print time and 2+ kg of filament, you can snag the files here: http://www.thingiverse.com/thing:1014884
DonaldJ
The PrintrNot?
Re: The PrintrNot?
Postby carlos » 2015-Oct-Thu-23-Oct
That's impressively large. Is it pretty rigid and how's the print quality?
Printrbot Simple Metal (using Rev F board) with E3D hot-end and heated bed.
carlos
Re: The PrintrNot?
Postby thawkins » 2015-Oct-Thu-23-Oct
Re: The PrintrNot?
Postby DonaldJ » 2015-Oct-Thu-23-Oct
DonaldJ
Re: The PrintrNot?
DonaldJ
Re: The PrintrNot?
Postby carlos » 2015-Oct-Fri-09-Oct
@DonaldJ if it wasn't due to operator error, I don't think a lot of us would be born. ;) Looking forward to seeing the end result. How much do you estimate the cost for everything was at this point?
carlos
Re: The PrintrNot?
Postby DonaldJ » 2015-Oct-Fri-16-Oct
DonaldJ
