Bonjour... Hi
Bonjour... Hi
Postby 2Mylent » 2015-Feb-Tue-16-Feb
Bonjour de France ;)
Nouveau heureux possesseur d'une Printrbot Simple Metal :geek:
New happy owner of a Simple Metal Printrbot :geek:
:D
Printrbot Simle Metal + Upgrade Heatbed / Upgrade E3D v6 / Simplify3D / Win7 64bits
http://www.2mylent.fr/Helicos/
FRANCE
2Mylent
Bonjour... Hi
Re: Bonjour... Hi
Postby RetireeJay » 2015-Feb-Tue-17-Feb
Bienvenue!
______________
Re: Bonjour... Hi
Postby 2Mylent » 2015-Feb-Wed-11-Feb
Thank you :D
Misadventure ("Simple Metal - assembled").
Parameterization, calibration, test the famous cube ..... bam, after 5mm, nothing, the printer stops. I am looking for and I finally realized that it was the AC / DC power supply is dead! ... :o
Message Ticket Printrbot on the site of a response in 24 hours with a replacement shipment of AC / DC. :ugeek:
TOP Printrbot#com :P
FRANCE
2Mylent
Re: Bonjour... Hi
Postby Mooselake » 2015-Feb-Wed-11-Feb
Did they send a dual voltage, or 120V, supply. Maybe it couldn't handle 220?
Re: Bonjour... Hi
Postby 2Mylent » 2015-Feb-Wed-14-Feb
It was good 220v AC / DC (YU 1206) with a patch on the socket for switch from US to EU..
FRANCE
2Mylent
