Greetings from Michel Bevan
Postby Michel-B1979 » 2017-Sep-Sun-10-Sep
Hi,
My name is Michel Bevan, I'm a Network Admin for a smaller IT firm based in Berlin, Germany. I've worked in the IT field for about 6 years, working for Intel for quite some time as a network admin/teacher, and some contract works for the gov't. I've been building programmable robots since I was 19.
I am looking forward to gaining from the huge amount of information here and hopefully help others along the way.
Many Thanks.
Michel-B1979
Re: Greetings from Michel Bevan
Postby RetireeJay » 2017-Sep-Sun-18-Sep
This forum is oriented to people who own, or are thinking of owning, a 3D printer, usually one made by Printrbot. May I ask what kind of 3D printer you have or plan to have?
Postby Mooselake » 2017-Sep-Mon-13-Sep
This exact same post has been made in several unrelated forums. It's coming from a US based IP address belonging to digitalocean, a VPN hoster. It is not listed in stopforumspam, although using a VPN might be the reason. He did spend an hour here, a point in his favor.
We should keep an eye on this user. It might be someone not real familiar with English who has varied interests, but...
Postby RetireeJay » 2017-Sep-Mon-14-Sep
Totally agree, Mooselake. When a post is obvious spam (totally devoid of content, necroposted on an ancient thread), I have no problem deleting it and banning the user. But On the off chance that a real user might get off to a slow start, I sometimes try to give a little opportunity for explanation and a little guidance on the real purpose of the forum.
Postby Michel-B1979 » 2017-Sep-Tue-10-Sep
Thanks, all of you for understanding me.
Regards
Michel
Michel-B1979
Postby Mooselake » 2017-Sep-Tue-13-Sep
Yes, we understand you. Unfortunately we have way too much experience with forum spammers.
You just made the same post in another, unrelated, forum that I read regularly.
Goodby, Michel, or whatever your name really is. Sorry it had to end like this. I was hoping you really were another network administrator.
