Printrbot Talk Forum • View topic - Good experience with healthyfatboy w/machined Al print bed
Postby plexus » 2013-Nov-Tue-22-Nov
I saw selling machined aluminum print beds. so I commissioned him to make one for me. This is for my PB+. We decided on MIC6 at 1/4" with a thin channel milled out for a thermistor and a platinum temperature sensor. Here are pictures of them in the channel. This bed is about 228mm square. It will be mounted on a 6016 1/8" aluminum platform on a teflon bronze bushing carriage on a rail. that will be my new Y. The sensors will be cemented in with Arctic Silver or Alumina. If Silver I will have to make sure the teflon sleeves are up against the sensor body and likely coat with CA glue so that the Arctic Silver doesn't make contact - it is not conductive but it is slightly capacitive which would reduce response time. Probably not a big issue on the print bed due to its huge thermal mass. But if it can be mitigated easily its worth doing. I digress...
The final result speaks for itself: excellent work and thank you
Re: Good experience with healthyfatboy w/machined Al print b
Postby healthyfatboy » 2013-Nov-Tue-22-Nov
Glad it made it there quickly and you are happy with it. Good luck and enjoy printing!
Printrbot LC Kit in PrintrBOX
PB bed stabilizer, leveler, fan mount, Y belt tensioner
Printed X-axis belt tensioner, spur gears, Z stabilizer
GT2 belts and pulleys
ACME lead screws and nuts
Hotend support ()
0.4, 0.35 mm nozzles, eventually 0.2 mm
Reflectix and 3M metal tape under heated bed
Plain glass for now
healthyfatboy
Return to Merchant feedback (good and bad)
