Printrbot Talk Forum • View topic - Metal Plus
Metal Plus
Metal Plus
Postby Willy » 2015-Jan-Sun-02-Jan
I am wondering whom out there has one?
I keep searching Youtube to see posts on it. Yet all I see are the ones that Brook has done.
Can some one elate what the unboxing was like?
Any other info I should know about the Metal Plus?
Willy
Metal Plus
Re: Metal Plus
Postby kbowen99 » 2015-Jan-Sun-11-Jan
Printrbot is still very far behind on shipping if you are considering ordering... (waiting on a metal plus upgrade)
kbowen99
Re: Metal Plus
Postby keljam7 » 2015-Jan-Sat-02-Jan
Yes I got mine about 3 weeks ago, I love it. If your getting one with a dual extruder, keep your nozzles in check because some are a little different in length. That is if you have the old hot ends. I just encountered this problem, the second extruder was rubbing the print leaving lines in it. So I thought it was not level and i made adjustments and that did not help. It was the nozzles all along.So there's is one tip.
It's a very nice printer, you should get one.
-kelly
keljam7
Re: Metal Plus
Postby JonS » 2015-Jan-Sat-15-Jan
I've had mine a few weeks. I bought it assembled, as I had a baby on the way (she came earlier than I expected and the printer came later than I expected).
I'm very impressed with it. The quality is a big step up from my V1 Jr, and the size and dual-extruders take me in to a different league.
I didn't like the recommended (and configured) Cura and haven't got everything quite sorted out in Repetier, so I jumped to Simplify3D which I'm mostly extremely happy with.
I've been a little limited on my printing, as it's a little noisy and as I said, we have a new baby. I had my Jr in a special enclosure I built with sound-absorbing foam. I'm in the middle of building my new enclosure now.
Printrbot Metal Plus with:
- Dual Gear Head extruders
- Heated bed
- PEI print bed film
JonS
Re: Metal Plus
Postby keljam7 » 2015-Feb-Wed-22-Feb
keljam7
Re: Metal Plus
Postby Willy » 2015-Feb-Fri-15-Feb
would one of you kindly post what area it takes for one of these printers to operate?
Willy
Re: Metal Plus
Postby JonS » 2015-Feb-Fri-16-Feb
- Heated bed
JonS
