Printrbot Talk Forum • View topic - printer configuration
Postby johnlack1123 » 2014-Mar-Tue-14-Mar
I have a Lenovo Thinkpad, Type 1141 A24 with Windows 7 and when I reciieved it I set it up as 64 bit machine. I got a message stating that there was no driver software for this type of machine. I then re-installed the operating system and configured for 32 bits. I have tried serval times to install the driver and I get the message there is no port avaiable. Any help would be apppreciated.
John
johnlack1123
Re: printer configuration
Postby REPRAP SQUAD » 2014-Mar-Tue-16-Mar
I have a win 7 laptop and when I installed everything and flashed the firmware. I had to manually install the usb driver. The details on how to do it can be found on my site: the page name is at the top and named "Everything Printrbot All in One Place." On that page you can than go down to where it says getting started guide. I believe it was put together by pxt as its an older guide but, it does a good job of explaining the process.
That page on my site has just about everything you would ever need for the printrbot owner. Its full of links, diagrams, how tos, explanations and all kinds of good resources. If you have any other questions or need a direct link let me know. My page is www.reprapsquad.wordpress.com
