How can I get started making 3D models for printing?
Postby allanonmage » 2013-Jun-Wed-10-Jun
How can I get started making my own models suitable for 3D printing? I know there is CAD software, Google has an in-browser 3D modeler of some kind (not sure if it's CAD or not), and I can only imagine that there are some expensive software packages out there too.
I've heard of Google sketchup, and I think GrabCAD has some sort of in-browser 3D modeler as well. I've heard of TinkerCAD and maybe a few others.
What are some other names of products out there? Are there different types? Are some better than others?
I don't have much for a budget, so eventually when I get to trying out the software, I'd prefer a free software I can download and run locally on a machine. In-browser is great for cross-platform and all, but the always-required connection is a big turn off for me, even though i suspect it will not cause a problem. That and Firefox memory usage usually swells on me so I'd rather not add more fuel to that fire.
If you can get me started, I can google the details, but I didn't get very far googling on my own.
allanonmage
Layer 100 of 1234
Re: How can I get started making 3D models for printing?
Postby RetireeJay » 2013-Jun-Wed-10-Jun
Did you try this thread? viewtopic.php?f=26&t=150
Postby allanonmage » 2013-Jun-Wed-14-Jun
That should get me started!
allanonmage
Layer 100 of 1234
