Thingiverse
Thingiverse
Postby bbrown64 » 2016-Mar-Sun-08-Mar
Thingiverse is not working for me today 3-20-2016. No matter what I put in to search. It comes back with 0 results. I restarted my computer to check to see if that corrected the issue. It did not. I removed it from my bookmarks as well. Still did not make any difference. So I sent Thingiverse a message about not working.
Bill Brown
Tulsa, OK
bbrown64
Thingiverse
Re: Thingiverse
Postby orangefurball » 2016-Mar-Sun-12-Mar
Works fine for me!
Thingybot Delta Printer
http://www.thingybot3d.com
orangefurball
Laser scintillater
Re: Thingiverse
Postby JonS » 2016-Mar-Sun-23-Mar
Works fine for me too.
Are you sure you are connected to the internet?
Printrbot Metal Plus with:
- Dual Gear Head extruders
- Heated bed
- PEI print bed film
JonS
Re: Thingiverse
Postby frankv » 2016-Mar-Mon-03-Mar
Try clearing your browser cache
frankv
First blob a success!
Re: Thingiverse
Postby olendorf » 2016-Mar-Mon-06-Mar
It wasn't Bill's pc problem. It was not working for me either. The must have fixed it pretty quickly though.
olendorf
Re: Thingiverse
Postby thawkins » 2016-Mar-Mon-07-Mar
olendorf wrote:It wasn't Bill's pc problem. It was not working for me either. The must have fixed it pretty quickly though.
Most large services are run via a "farm" of servers, often 100's, it's common for a bad code deployment to effect only a subset of machines that make up the service, hence different people can see a service as working or not working based on which server they get attached to when they start thier session.
