Printrbot Talk Forum • View topic - Jonbot Plus - a new fully printed printer!
Re: Jonbot Plus - a new fully printed printer!
Postby orangefurball » 2015-Oct-Tue-20-Oct
Thingybot Delta Printer
http://www.thingybot3d.com
orangefurball
Laser scintillater
Postby frankv » 2015-Oct-Thu-20-Oct
Arrrgghh... Apologies for allowing my confusion to infect this thread!
I had overlooked the Jonbot PLUS, and am building a Trirod bot, which is based on the original Jonbot.
Now that I've looked, I see that my ideas for a gantry system do closely correspond to what the JonBot Plus has. I believe that this demonstrates the genius of Jon Lawrence. :mrgreen:
Postby orangefurball » 2015-Oct-Thu-21-Oct
orangefurball
Laser scintillater
Postby orangefurball » 2015-Oct-Fri-20-Oct
Quick little update, I finally installed my E3D Cyclops and got Repetier Firmware setup on my JB+! Just setting up the extruders now then I'm ready to print! Already did some tests with the old extruders and it works great! 20151009_212849.jpg20151009_212857.jpg
orangefurball
Laser scintillater
Postby orangefurball » 2016-Jan-Tue-02-Jan
Small update today. Jonbot Rev 1.802728263 (that sounds good) is done!
Spool on top, back to one extruder on bottom, stabilizing bar for the Z axis, MDF sandwich with Ramps and power supply contained and some messy wiring.
I'll figure out something to do with the LCD one day, I also have a strip of LEDs for the top. The MDF is held up by simple printed supports and the whole base was shoddily spray painted in the 0 degree wind earlier in the night.
The Jonbot is the workhorse that just doesn't quit, I love the darn thing!
Edit: forgot to mention I'm back to Marlin. Repetier was alright but there's nothing like the simplicity of "it just works" Marlin.
orangefurball
Laser scintillater
Postby KD6HQ » 2016-Oct-Sat-04-Oct
I started this project last year and never got around to finishing it.
A few weeks ago I thought it was time to finish it. It took a couple of weeks just to figure out where I was in the process and update myself
on things that have changed since I last thought about this printer. The reason I had decided to originally build it was based on the Idea of the
way the hot end was supported I thought it would be more stable than my existing printer was. Also there was the idea of using a glass bed
because it would be leveler than my un-machined aluminum bed.
I have made a few changes. Since last time I looked at it a "new" IR sensor has been developed and in use for several months now. After
looking into it I decided to purchase one. It is working very well with a glass bed, more about that later.
I am using spring loading on the corners of the bed. It is a very simple way to be able to adjust the bed for leveling. The bed is made up of an
aluminum plate, cardboard, heater, glass and a sheet of PEI on the top.
PEI, IR sensor and glass. The IR sensor will see thru the PEI and glass unless something is placed in the way. Since the PEI is 1mm thick and the
double strength glass that I am using is 3.175mm. I'm not sure but I think the IR sensor would be reflecting off the heated bed which would give
incorrect information back to the IR sensor as far as distance to the printing surface would be. What is recommended by the manufacture is
to paint one side of the PEI with high temperature, flat black paint. This is what I did and it is working well. I still have to deal with 1mm difference
between the reflective layer and the print layer but that is a lot easier than dealing with 4.175mm (glass & PEI).
At this point I only have a little tweaking to do in the firmware and I should be able to start using it. Guess I should also go back and clean up the wiring etc.....
Electronics:
RAMPS 1.4, Arduino Mega 2560,
IR Sensor, Mini Differential IR Height Sensor : Read about it here"
https://miscsolutions.wordpress.com/min ... sor-board/
Firmware: Marlin RC-6 modified.
Hardware:
Steppers Nema 17 72oz. in.
Rods: 500mm x 8mm
Hand full of custom printer parts for
Double wall Cardboard (local UPS store), works very well as heat insulator.
Hot end E3D Lite6
Other parts bearings etc. common to all 3 d printers.
Core XYZ
It's all in the details!
KD6HQ
Postby RetireeJay » 2016-Oct-Sat-07-Oct
Impressive work. Just one comment: It looks like your bed would be liable to vibrate when the printer is doing small infill zig-zags because those bolts supporting it are so long (and relatively thin). You might find that shorter, thicker bolts would give you better support for the bed in the X-Y axis. For leveling the bed, you shouldn't need more than a couple of mm of spring compression available between "reasonably pre-tensioned" and "compressed to a solid."
Postby KD6HQ » 2016-Oct-Sat-09-Oct
Thank you RetireeJay for the commits.
I had not thought about the vibration, I think that is a something I will need to watch.
If needed that will be easy to change. The current mounting screws are 50mm x 3mm
and the gray mounting plug could easily go to 6mm if needed.
Core XYZ
KD6HQ
Postby KD6HQ » 2016-Oct-Sat-17-Oct
I ran a G29 today, now if I only knew what I am looking at.
EQn coefficients: A: -0.00036486 b: -0.00072760 d: -8.59633731
Bed Level Correction Matrix:
+1.000000 +0.000000 -0.000365
-0.000000 +1.000000 -0.000728
+0.0003650+0.000728 +1.000000
X:148.00 Y:246.01 Z:11.40 E:0.00 Count X: 11841 Y:39362 Z:44655
X:0.00 Y:246.01 Z:11.40 E:0.00 Count X: 0 Y:39361 Z:45587
X:0.00 Y:0.00 Z:11.40 E:0.00 Count X: 0 Y: 0 Z:45587
Core XYZ
KD6HQ
Postby KD6HQ » 2016-Oct-Sat-03-Oct
Added second hot end
Core XYZ
KD6HQ
Postby KD6HQ » 2016-Oct-Mon-05-Oct
Seems to be working.
Printed test square, Gray/Yellow
Unfortunately on this one, the printer just stopped about 2 1/2 hours in to a 6 hour print?
I have the printer running a little slower on this one.
Core XYZ
KD6HQ
Previous
