Printrbot Talk Forum • View topic - 3mm ubis vs 1.75 same diameter hole
Postby wthierry » 2013-Aug-Thu-22-Aug
someone gave me a bunch of 3mm pla, so I bought a ubis 3mm .4 diameter hotend, to replace my ubis 1.75 when I want to use the larger filiment... is there a difference in print quality if both hot ends have a .4mm diameter hole in the end???? Im confused!
wthierry
Re: 3mm ubis vs 1.75 same diameter hole
Postby FuelCell250 » 2013-Aug-Thu-23-Aug
As far as I know, your print quality will be the same. The entrance and bore of the ubis are either 1.75mm or 3mm, but the nozzle is the same. I think the entrance and bore are 1.75mm now to make sure the 1.75mm filament doesn't flex side to side as it's pushed through the extruder.
FuelCell250
Postby Michele31415 » 2013-Oct-Sun-01-Oct
Hmm - so if I have a 3 mm. hotend, does this mean I can also run 1.75 mm. filament through it?
PB+ no. 2548 (Oct. 2012) - This is my Printrbot. There are many like it, but this one is mine.
GT-2 belts and metal pulleys, x&y; Injection molded extruder gears
40 mm. cooling fan, glass bed, LED extruder lights, pilot light
Anti-jam extruder feed tube, roller filament guide, soldered bed heater connection
Michele31415
Postby RetireeJay » 2013-Oct-Sun-12-Oct
  • 2
Postby Tdeagan » 2013-Oct-Sun-17-Oct
I'd be curious as well to see if the molten plastic didn't try and well up around the entrance, contributing to jams.
The 3 mm filament serves (to some degree,) as a piston on top of the molten pool. I can imagine 1.75 mm filament not serving that function as well.
Tim Deagan
KC5QFG
RAMPS 1.4 w/ LCD,
Quick Change Extruders:
MIC-6 metal bed
Thingiverse Profile:
Tdeagan
Postby Michele31415 » 2013-Oct-Mon-00-Oct
Hmm - sounds like I better not chance it. It's a shame too because there's a good deal on some 1.75 mm. glow in the dark ABS on Ebay. Being as Halloween is coming right up...
Michele31415
Postby Mooselake » 2013-Oct-Mon-09-Oct
You could use a short length of Teflon tubing inserted into the drive gear end of the hot end. Not sure of the exact size, but 4mm OD, 2mm ID sounds about right. It should be a snug fit into the UBIS, and you'd need to experiment with how far to push it in. Measure twice, order once...
I've got a kg of 1.75mm glow in the dark filament, waiting for my many months overdue QU-BD RPM. After the also delayed knee tuneup happens I should try this - if you go first I'd know what size tubing to get rather than my usual order a range of sizes technique. :-)
Postby Michele31415 » 2013-Oct-Mon-23-Oct
Well the guy on Ebay never bothered answering my question to confirm if his filament was really 1.75 mm. or not. In the meantime I found some glow in the dark, advertised as 3 mm. on Amazon for only three bucks more, and it's blue (!) so I ordered that. I don't even know where to get Teflon tubing.
Good luck with your knee tuneup.
Michele31415
Postby Michele31415 » 2013-Oct-Wed-00-Oct
Hmm - I just noticed that on Printrbot's web site, they give the specs for the Printrbot+ (here: http://printrbot.com/support/printrbot-plus/) as "Hot End: Ubis 1.75mm, 3mm". But it's not clear itf they mean you can get a hot end with one of two different sizes or if the one hot end can use both sizes.
Michele31415
Postby Mooselake » 2013-Oct-Wed-09-Oct
