Printrbot hot end, temperature sensor connectors
Postby accuprintr » 2019-Jan-Wed-13-Jan
I have a thermistor cable which has multiple breaks in it from being worn out. I was thinking of making a new cable, but I am unable to find connectors which are used by printerbot. Were they originally sourced from digikey? Is it possible to buy them on Amazon or eBay?
Proud owner of:
Printrbot Simple with Simple XL Upgrade kit, Printrbot Jr. V1/Jr. V2, Printrbot Simple Metal and Printrbot Original.
accuprintr
Re: Printrbot hot end, temperature sensor connectors
Postby RetireeJay » 2019-Jan-Wed-14-Jan
This thread should give you all the info you need:
viewtopic.php?f=21&t=4567
