New user
New user
Postby pinkupriyanka » 2018-Dec-Wed-08-Dec
Hello everyone,
As I'm new to this forum i want to know how this forum is useful for me, what will get and what knowledge can I spread to you all. Basically, how does this forum works??
pinkupriyanka
New user
Re: New user
Postby RetireeJay » 2018-Dec-Wed-16-Dec
This forum is for people who use Printrbot 3D printers. It is primarily for sharing information about how to use, repair, or modify these printers. We do not accept advertising or discussions that are not relevant to Printrbot 3D printers. Also, you should know that this forum is slowly dying because the Printrbot company has gone out of business.
