Main board installation
Postby dlw » 2017-Mar-Fri-19-Mar
Main board came yesterday.
Even though its an 'F', its different than what was there. (See attached)
The two white connectors on the right side of photo are both marked fan.
Is the way it is set now correct?
I also bought a heater, glass bed and power supply.
Post about those will follow.
Thanks,
dlw
dlw
Re: Main board installation
Postby RetireeJay » 2017-Mar-Fri-21-Mar
One fan is for the print; its speed can be controlled in G-code. The other fan is for the Hot End; it probably comes on at 100% when the Hot End temp is above 50C. Or maybe it's on all the time; I don't know for sure.
Postby dlw » 2017-Mar-Fri-21-Mar
Thanks for replying.
I'm being careful. I've already had to buy one main board. Do not want to buy another.
dlw
dlw
