Printrbot Talk Forum • View topic - Heatbed problem
Heatbed problem
Heatbed problem
Postby dlw » 2017-Jan-Thu-20-Jan
Purchased a heatbed
As shown in the photo, one end is missing.
Where can I get one?
Also, which lead is for the heatbed itself?
dlw
dlw
Heatbed problem
Re: Heatbed problem
Postby AZBotr » 2017-Jan-Thu-20-Jan
The wires with the plug should go to the thermister port on your printrboard to feed the temperature readings. The bare wires would screw into the terminal blocks behind the mosfets on the Rev F boards (opposite side of the board than the thermister port.) Rev D boards I think are in the same area but do have pins to receive a plug. Do you know which board you have?
AZBotr
Re: Heatbed problem
Postby dlw » 2017-Jan-Thu-21-Jan
Thank you for replying.
So, I would have guest right.
Now, I need a good printer board and power supply.
dlw
dlw
Re: Heatbed problem
Postby Mooselake » 2017-Jan-Fri-12-Jan
Way back in October you said you were ordering a new Printrboard. Did you receive it, and was it a Rev F? If so, did the new board ever work?
