Heated Bed Wires
Heated Bed Wires
Postby New Passion » 2017-Jan-Sat-21-Jan
Hi, I have a friend of mine that just bought a used Simple Metal, and he wants to put a heated bed on his, like I have on my printer, but his heated bed pcb he bought has two black wires. Mine has one red wire and one black wire. His Board is a rev F4 with the screw terminals for a heated bed, and the heated bed pcb he bought off ebay is 12v. He wanted to know if it makes a difference as to which screw terminal he attaches his wires, since they are both black wires. I told him I didn't think it made a difference, but I would ask on the forum. Thanks.
Mark
New Passion
Heated Bed Wires
Re: Heated Bed Wires
Postby Mooselake » 2017-Jan-Sat-21-Jan
No difference
Postby RetireeJay » 2017-Jan-Sat-22-Jan
Mooselake wrote:No difference
Agree.
Unless... Some heated beds have little LED indicators on them to tell you when power is being applied. If that's the case, and if the LED doesn't light up, then simply reverse the wires. No damage will occur regardless of which way the wires are hooked up.
Postby New Passion » 2017-Jan-Sun-10-Jan
Thanks for the quick responses, I'll call and let him know today.
New Passion
