by RetireeJay » 2015-Jun-Sat-11-Jun
I'd suggest you look on the Showcase part of the forum to see what printed products look like Also look at the thread "Printing Small." No one is ever going to mistake printed parts for injection-molded parts, but nevertheless they can be quite attractive. If you have a heated bed and print with ABS, you can do vapor smoothing and get some very nice-looking parts.
There are a variety of settings, particularly layer height, that affect print aesthetics. These same settings are available on all models of Printrbot. For the most part, aside from sheer size, the different models of Printrbot can all produce essentially the same quality prints. Some of them can run faster; the Simple will be the slowest of the family for a given quality.
It sounds like you're planning to make several of these objects, perhaps for sale as part of a larger assembly or project? If you are really interested in quantity production, then a larger model Printrbot can print more of them in a single run, tiling them on the bed.
If these parts will be joined with other things in an assembly, do you have expectations or requirements for mechanical strength? Tolerance for fit with other objects? Temperature tolerance? (PLA can't take the heat of the interior of a car in the summertime). Safety concerns? Food-grade materials? Requirements for color, opacity, surface sheen, etc?
If dimensional tolerance is your biggest concern, then the answer to your question is that you can fine-tune your settings (and model, if necessary) to get pretty tight tolerance, but don't expect repeatability to be better than one or two tenths of a millimeter from hobbyist machines.
I say all this because if your purchase decision depends on having a truly representative sample from someone on this forum, then you've got to be very thorough in how you specify what you need. A thousand of us could print your file, and there's be a thousand tiny, tiny (or big) differences between all of them.
