by RetireeJay » 2015-Jan-Fri-11-Jan
Your buddy doesn't even understand the basics of 3D printer orientation. The only sane way to even attempt to print this would be with the large-diameter open circle in the X-Y plane, with the dome building up in the Z direction. Depending on the material you are using, the layer thickness, the trace width, and the use of fans, etc, the steepest "overhang" angle you can expect to do is between 45 and 60 degrees. Beyond that point, you're just dropping threads into the air. And printing this single-wall object with support (made of the same material on a single-printhead printer) is going to create a very messy object that will probably break before you can get it separated from the support.
I had a few minutes of spare time [Retired...] so I re-oriented your model in Netfabb and gave it a try. As I predicted, the overhang failed at about the 45 degree angle. I note that your model is only about 0.2mm thick. My nozzle (and therefore my minimum trace width) is 0.4mm, so the end product may have the right shape but there's no guarantee that it would fit on your doll-sized cup. In fact, achieving that precision is going to be difficult!
