Printrbot Talk Forum • View topic - Ubis hot end
Ubis hot end
Ubis hot end
Postby ElmoC » 2014-Dec-Wed-09-Dec
I just had a print go terrible wrong and as a result, filament got pushed up so far under the insulating sleeve it severed the wire to the heating coil. Printrbot is out of stock on all their hot ends. Does anyone have a spare they would be willing to sell?
ElmoC
Ubis hot end
Re: Ubis hot end
Postby evanalmighty » 2014-Dec-Wed-11-Dec
Now is a good time to look into E3D or other hotends. I'll never use Ubis hotends again.
evanalmighty
Re: Ubis hot end
Postby ElmoC » 2014-Dec-Wed-11-Dec
What does it take to switch? I had thought about switching to another hot end but hadn't investigated what it takes to mount one and what changes to the controller is needed. You have any links or suggestions about it?
ElmoC
Re: Ubis hot end
Postby musk » 2014-Dec-Wed-12-Dec
You could also fill out a support ticket with Printrbot to see if they'll fulfill an order through there.
Printrbot Metal Plus (2x)
Printrbot Simple Metal (2x)
musk
Re: Ubis hot end
Postby ElmoC » 2014-Dec-Wed-12-Dec
ElmoC
Return to Need a part
