Ubis hot end 3mm
Ubis hot end 3mm
Postby rho-wan » 2014-Sep-Fri-14-Sep
Hello, I would like to buy a Ubis hot end for 3mm filament but I cannot find it on the store.
Any idea where to find it?
Thanks.
PrintrBot LCv2 and ABS. Flipped PCB with alu 3mm plate and then kapton on top, plus hairspray. Three paper rings ("frames") between PCB and alu plate, to compensate for the bulging PCB when warm.
Sunflower oil between PCB and alu plate to try to improve heat conduction (better than air anyway!)
rho-wan
Ubis hot end 3mm
Return to Need a part
