Printrbot Talk Forum • View topic - Printrbot Jr Heated Bed Upgrade?
Postby mothy » 2014-Jan-Sat-14-Jan
I noticed that printrbot.com no longer carries the heated bed kit for the Jr. Does anyone have one for sale or have an alternate method of adding a heated bed to this so I can start enjoying the benefits?
mothy
Re: Printrbot Jr Heated Bed Upgrade?
Postby REPRAP SQUAD » 2014-Jan-Sat-19-Jan
I've seen some on eBay with the same size requirements of the Jr. I would look there if you can't get one through pb
Postby KDog » 2014-Jan-Sat-23-Jan
Makerfarm.com carries several different sizes including a 4.5x6 and a 6x6.
Printrbot Metal Simple
KDog
Postby mothy » 2014-Jan-Fri-09-Jan
I have no idea how to hook up the heated beds, is there a tutorial on doing this for the printrbot JR? I'd rather just buy the kit, but there are a couple vendors selling it for $99 now when printrbot sold it for $65 just a month ago
mothy
Postby Mochaboy » 2014-Jan-Fri-09-Jan
Avanti circuits on ebay sells the pcb heater but you'll have to do some soldering/wiring.
just search for 4x5 heated pcb
This was for the original:
http://www.ebay.com/itm/New-4-5-X-6-Hea ... 3cd075e9fe
i used a 1/8" aluminum plate for my print plate but you can use whatever you want.
Printrbot Jr born 6/13
Brass M8 Threaded Z Rod
Tool less belt tensioners
Aluminum print plate
Mochaboy
Print winner 1st
Print winner 1st
Postby mothy » 2014-Jan-Sat-11-Jan
yeah thats not what i'm looking for, i'm looking for the printrbot JR heated bed upgrade with the new laser cut wooden print bed with "jr." stamped on it. The one that was $65 and had all the parts...
mothy
Postby takingblame » 2014-Jan-Sun-20-Jan
I was looking for the same thing. After some research it's actually better to get the 4.5x6 in heat bed from eBay. It maintains the same print volume and is cheaper. But it will take some setup. For example you can't run a heated bed on just the laptop power supply. You would need the atx powery supply. Also, you would need to add a thermistor to the heated bed. The eBay seller does have the option to pre solder the thermistor. But I would rather tinker my way to a heated bed, then give up valuable print volume.
takingblame
Postby mothy » 2014-Feb-Sat-13-Feb
Cool, yea well i'm still looking for a viable option that requires minimal tinkering. Does anyone know of a tutorial or links to these heated beds on ebay and the appropriate thermistor? I have an ATX power supply already. Also is there a good source for the laser printed "JR" bed upgrade, or possibly a STL file that i can use to laser print my own?
mothy
Postby takingblame » 2014-Mar-Wed-23-Mar
For the ebay heated bed. I havent found any videos or tutorials for getting this up and running. What you will do is purchase the the pre wire option, the thermistor and the heated bed at the same time. Contact the seller to let him know that you purchased the pre wire option and boom, pre wired PCB heated bed ready to be plug and played. You just need to find the right spots on the board to plug in to, and a firmware upgrade might come in handy as well.
As for the laser cut parts, check the PB website, on there you can find all of the design files for the laser cut wooden parts for the printrs but i am not sure if you can find the heat bed laser cut files.
takingblame
Return to Need a part
