I try to keep all my rods as clean as possible. X rods/bearings build up dirt on the extra greese on the rod ends rapidly. Out of site is out of mind.
Anyhlw, I saw the video from PB showing how to use hairspray on the PB Simple Metal bed to assist ABS to stick to the bed.
Hair Spray Adhesive for ABS with the Printrbot Si…:
http://youtu.be/WvvBX3LQ5As I used to use a glue table for spray glue to attach patterns to wood for scrolling. The overspray grew so thick against the sacrificial cardboard and acted like a magnet to dirt, sawdust and dog hair (no dog there!).
The video made me cringe since the hairspray was sprayed directly on the printer bed. Bed was cleaned and sprayed before each print. Hairspray is a water soluable adhesive and will do the same thing. Build up adhesive from overspray, dirt and hair real quick.
For some reason I thought beople were taking a glass (or other) bed off their printer, spraying it and then put it back on to print. That's what I would do for that method. Otherwise the printer, rods and bearings are getting an overspray of hairspray as well.
I'm not saying this is what happened to anyone's specific printer, but talk of the faulty bearings reminded me of this. Keep em greased and clean.
Ed
Complete printable 1405 Simple
https://www.youmagine.com/designs/compl ... s-edition/ or thing:425164
True Wireless Slicing and Printer Cloud+Web Server w/ AstroPrint PcDuino v2 Printrbot Simple 1405 with XL bed and
