Printrbot Talk Forum • View topic - I need hot end insulation tube.
Postby Vapor » 2016-Dec-Sat-16-Dec
I'm being cheap and don't want to spend $15 for tubing I can buy for a couple bucks at McMaster.
But then again, I dunt want to order enough stuff from McMaster to get past their minimum order.
Does anyone have any extra that they'd sell for a few dollars?
Vapor
Re: I need hot end insulation tube.
Postby KD6HQ » 2016-Dec-Sun-12-Dec
You did not specify what size but there are lots on e-bay, here's just one if you want 2mm id / 4mm od
http://www.ebay.com/itm/121938986292?_t ... EBIDX%3AIT
Printrbot Simple Makers Kit (1405) modified.
Core XYZ
It's all in the details!
KD6HQ
Postby frankv » 2016-Dec-Sun-14-Dec
I think he wants the red insulation stuff, not PTFE tube. I recall reading that this stuff is available from auto parts stores as pipe insulation?
frankv
First blob a success!
Postby teicher » 2016-Dec-Sun-21-Dec
It is available at some auto stores. It's called fire sleeve and you can find it on ebay too. I will say that whatever version printrbot uses is a little nicer and harder to find.
teicher
Postby Mooselake » 2016-Dec-Sun-23-Dec
Or you could join the few and proud and get ...
Sources for the sleeve (sometimes called a sock here) have been discussed in the past. Use the forum search (upper right corner of the page in a desktop browser) to find them.
Postby plexus » 2016-Dec-Mon-18-Dec
Postby DonaldJ » 2016-Dec-Mon-21-Dec
A toeless sock? I call it a "nozzle cozy."
DonaldJ
Postby Mooselake » 2016-Dec-Mon-22-Dec
Saying it's sometimes called a sock isn't acquiescing, just helping with searching for misnomers.
Not sure about nozzle cozy, need to ruminate on that for a while
Postby plexus » 2016-Dec-Tue-01-Dec
CAUTION: MOOSE RUMINATION!! PROCEED AT OWN RISK.
Postby Vapor » 2016-Dec-Tue-01-Dec
What diameter is the sock?
I'll check with the local shops and see what I can find
Vapor
Postby Mooselake » 2016-Dec-Tue-12-Dec
I measure my red sleeve at 3/4" ID (within a thou), and a 64th over that OD. The frenchified numbers didn't come out even so PB probably english measurement based products.
Now that's after 4+ years of use, might have accidentally stretched from metric to english sizes. It's stuck on (didn't heat up the extruder) so I can't measure it flat.
Here's your chance to start a new color trend!
Postby New Passion » 2016-Dec-Tue-18-Dec
Here is a link for some I ordered off of Ebay. It's not Bright red.. kind of a brick red, but it works, I think I saw blue on there also, check sellers other items if you want blue.
Here is the link: http://www.ebay.com/itm/1-2-12MM-FIRE-S ... 4d1d0fb8de
New Passion
Return to Need a part
