Printrbot Talk Forum • View topic - STL File for Printbot Plus 1303 FEET
Postby smisra1968 » 2016-Sep-Fri-14-Sep
I found the DXF's but having a hard time converting it to an STL file. does anyone have an STL or can someone take a DXF and convert it into STL for me please?
Thanks,
Sachin
smisra1968
Re: STL File for Printbot Plus 1303 FEET
Postby RetireeJay » 2016-Sep-Fri-16-Sep
The DXF is a 2-D file; you need to use a CAD program of some type to "extrude" it into a 3-D part and then make it into an STL. And BTW, the original DXF that you put in your PM had a couple of errors - but I recognized the drawing and was able to fix them easily. If in the future you think you may want to create more STL files from DXF then I suggest you look for a free CAD program. For one example out of many, is a browser-based package that's free for home use, with up to 10 private documents or unlimited public documents.
One thing that I had noticed about the original plywood feet is that they were a bit flexible in the machine's X direction. When there was some small infill being created that involved lots of short motions of the extruder in the X direction, I could see the feet bending, allowing the whole machine to vibrate. So I designed and printed replacement feet, and I've included the STL file for them as well as the original feet here, so take your choice. In either case, print them at 100% infill.
Postby Mooselake » 2016-Sep-Sat-08-Sep
To extend RJ's CAD comments a bit, there's several free (both open and closed source) CAD programs you might want to look into, since they'll become handy in the future. Solvespace is on my to-check-out list, FreeCAD is getting better, Fusion360 (free for hobbyists) is an often recommended choice as is Design CAD 3D. There's some online programs that work through your web browser (TinkerCAD, for example, where I made my first ever 3D design).
Most CAD programs have a steep learning curve, so expect to spend some time. Of course, this moose started with non-computer aided drawing using natural organic devices (paper, pencil, basswood portable drawing board, masking tape, etc) with some oil derived accessories like plastic triangles and finds this new-fangled CAD stuff somewhat daunting. I mostly use openSCAD (which will also extrude DXFs), but then again I'm a programmer.
Postby smisra1968 » 2016-Sep-Sat-10-Sep
Thanks for the quick replies, much appreciated. I do use SolidWorks 2010. I know it's a bit dated but it works for what I need it for. I'm still a novice but can usually get through simple geometric designs. Maybe it was the error in the original DXF but Solidworks refused to import the file as a 2D file.
Thanks again!
smisra1968
Return to Need a part
