Thermistor Cable Connector [Source Found]
Postby rigarashi » 2015-Aug-Mon-04-Aug
Does anybody know the name, part number and source to buy some of this thermistor connector? The wire harness side of the connector is all I need but need 3 at least. That's the one encircled in red. The wire harness cable for the thermistor stressed out and the cable opens intermittently. I need to replace the whole length of the cable. The connector on the printrboard side is quite common, but the hotend side is what Í need. If I can get the name and part number, I can probably find the source on line. Can anybody help?
I'm in Chiba City, Japan (one of the suburban cities of Tokyo).
rigarashi
Re: Thermistor Cable Connector
Postby RetireeJay » 2015-Aug-Mon-06-Aug
Here you go: viewtopic.php?f=21&t=4567&p=41427#p58954
The whole thread is very informative.
Postby rigarashi » 2015-Aug-Mon-07-Aug
Bookmarked it... thank you!
rigarashi
Return to Need a part
