Parts are available for purchase
Postby drphil3d » 2019-Jul-Tue-13-Jul
If anyone is looking for Parts for their Prinrbot you can contact me phil @ pintrbot com or visit my website, I'm still listing item. I don't have any printrboards.
drphil3d
Re: Parts are available for purchase
Postby RetireeJay » 2019-Jul-Tue-16-Jul
Phil, you mention having a web site, but it's not obvious how to find it. If the forum doesn't let you post a direct link yet (there's a threshhold number of posts required before you can post links), you can always use spaces or parentheses like MyPrintrbotStore(dot)com
Also, more generally speaking, we have a forum section here called "Marketplace" with a sub-forum for "3D Printing Merchants" which I think would be more appropriate for this post.
-RetireeJay
Return to Need a part
