Printrbot Talk Forum • View topic - Wax filament
Wax filament
Wax filament
Postby PxT » 2015-Jun-Mon-15-Jun
I got a sample of wax filament to test out and I'm trying to decide which object(s) would make a good test for this material. Any great suggestions? Anyone else used this filament yet?
Wax filament
Re: Wax filament
Postby JonS » 2015-Jun-Mon-15-Jun
Is it Kai Parthy's MOLDLAY?
Do you intend to create lost wax molds for casting?
Printrbot Metal Plus with:
- Dual Gear Head extruders
- Heated bed
- PEI print bed film
JonS
Re: Wax filament
Postby frankv » 2015-Jun-Mon-16-Jun
Re: Wax filament
Postby PxT » 2015-Jun-Mon-17-Jun
Re: Wax filament
Postby JonS » 2015-Jun-Mon-18-Jun
I wonder if it's possible to turn ear wax in to filament.
Hmm, sounds like a Kickstarter opportunity to me! ;-)
- Heated bed
JonS
Re: Wax filament
Postby Mooselake » 2015-Jun-Mon-20-Jun
How about a real candle, thread the wick in after printing, maybe doubled with a string or wire to pull it through.
Re: Wax filament
Postby mechanizedmedic » 2015-Jun-Thu-23-Jun
When I was a goldsmith we would mix wax and plastics on occasion. It was usually to get a texture/pattern from something (mesh) or to act as filler. Either way, a kiln will burn it out just the same.
blog.mechanizedmedic.org
mechanizedmedic
Re: Wax filament
Postby PxT » 2015-Jun-Tue-13-Jun
Had a bit of trouble getting good bed adhesion. Finally got going with a coat of 3M Automotive Trim adhesive, which was the stickiest spray I had on hand. The filament kinked and got jammed during that print but at least it stuck to the bed while it lasted. Will have another crack at it - making progress.
