Different colors, different strengths?
Postby rho-wan » 2014-May-Sat-18-May
Hello,
I am going to buy some new filament and I am evaluating a color different from my current bright green.
So I wondered, are different colors easier to use? maybe some melt at lower temperature, or they have different bonding strength, and so on.
Also, since I admit buying the cheapest filament I find around (and then I bake it in the oven), are there colors that are "easier" to manufacture and therefore more reliable when bought from unreliable manufacturers?
Thanks.
rho-wan
