Printrbot Talk Forum • View topic - Recycling ABS & PLA...
Postby DonaldJ » 2014-Mar-Fri-13-Mar
This is a response to the excellent post by AlexC (viewtopic.php?f=74&t=6631), regarding stuff I've been fooling around with for some time now. I don't have a garden, compost pile, or worm ranch, so this is what I do:
ABS: I keep a lot of ABS juice/slurry on hand for creating forms & objects in a process like laying up fiberglass. Paper towels, thin fabric; a lot of things work well. There are some materials that the ABS stuff doesn't adhere to: silicone, saran wrap, polypropelene, parchment paper (for baking). Test it first, though. The project will shrink and deform a bit (Yay! ABS!) but it can be beaten into submission with the judicious use of a heat gun.
PLA: This is a little trickier and unless you live alone you will definitely need approval of the Boss of the Kitchen. Heat your oven to about 410F (205C), put your PLA scraps in a non-stick pan/cookie sheet and just melt it. Use foil on the bottom of the oven; there may be spillover. Check it every ten minutes or so, You'll get air bubbles, so pull it out and pop the bubbles with anything that works and put it back in the oven. Repeat as necessary.
So, what good is it, you ask? You can laser cut PLA, or work it like any other plastic. You can make thick pieces that you can mill with a little CNC machine (like the ShapeOko). Or you can shape thin sheets with a heat gun, soldering iron; anything hot enough to melt it. Or use superglue, epoxy, tape, etc. It can be really fun stuff to play with and doesn't require a lot of imagination to use.
As always, use common-sense safety precautions (ventilation especially), and if it's too weird for you to consider, forget I said anything.
DonaldJ
Re: Recycling ABS & PLA...
Postby plexus » 2014-Mar-Fri-15-Mar
Excellent idea! and the ingot can just be marked with the plastic type and put in recycling. So non-stick pans release the plastic with no issues? PLA and ABS?
Postby DonaldJ » 2014-Mar-Fri-16-Mar
DonaldJ
Return to Material talk
