Printrbot Talk Forum • View topic - Flex Pla from makergeeks
Postby jaberman1 » 2014-Jan-Sun-18-Jan
I'm using Flex Pla from makergeeks and the edges like to curl up with a heated bed or no, and painters tape doesn't work, how can I make it stick?
Jonathan Haberman
jaberman1
Re: Flex Pla from makergeeks
Postby REPRAP SQUAD » 2014-Jan-Sun-20-Jan
Have you tried adjusting your skirt and brim settings within slic3r. I've found that different combination work depending on what your printing will change the combination. It serves as an anchor. I use it all the time and I haven't had a single issue since.
