Printrbot Talk Forum • View topic - Filament storage...
Filament storage...
Filament storage...
Postby DonaldJ » 2014-Jan-Sun-15-Jan
Over time, I've accumulated quite an array of filament of different sizes, materials, and colors; storage has always been an issue. I don't like those specialized containers, so I stumbled across a different solution; stretchy packing tape.
With a partially used spool, simply wrap it a few (or more) times with that stuff; add some dessicant if humidity/moisture is a problem. Then you can toss it in a box and store anywhere.
This method keeps the spool tightly wrapped and at least dust/dirt/animal hair free. Good for shop environments, too.
DonaldJ
Filament storage...
Re: Filament storage...
Postby RetireeJay » 2014-Jan-Sun-16-Jan
All the big box stores (both hardware and Wal-Mart / Target types) have a very wide variety of plastic tub storage boxes. Their tops may not seal perfectly, but I've found that you don't really need an airtight seal. A half a pound of crystal kitty litter in the bottom will keep the contents dry for years. (Dry the kitty litter in an oven at 175F or more for a couple of hours, then let it cool before putting it in the container.)
Postby DonaldJ » 2014-Jan-Sun-18-Jan
DonaldJ
Postby REPRAP SQUAD » 2014-Jan-Mon-08-Jan
I recently bought 3 spools of obsessed discount stuff and I'm quite impressed. You don't get to pick color and you usually get several different kinds but it's worth it. I probably have a pound of almost every color pb has now. I use the tub and kitty litter trick and it works well as I've never had steaming filament yet. I live in the nw also which is rain city.
Postby redwood » 2014-Jan-Tue-13-Jan
Printrbot Plus v2.1
redwood
Postby DonaldJ » 2014-Jan-Thu-12-Jan
DonaldJ
Postby redwood » 2014-Jan-Thu-16-Jan
Start getting rid of stuff. Its hard to do but liberating. I've been working on this since Christmas. Plus, you'll have more place for new stuff.
I'm thinking of filling up an SUV full of old stuff and selling it at the flea market. I would be able to get rid of it all in one shot and not have to deal with craigslist. I don't really care about the money.
Printrbot Plus v2.1
redwood
Postby DonaldJ » 2014-Jan-Fri-13-Jan
DonaldJ
Postby leon06 » 2014-Feb-Thu-02-Feb
I am a seller of filament making material in Rothwell. To store raw material and manufactured material, I have rented out a permanent Self storage in Rothwell for long-term at month-to-month charges.
leon06
Postby jeromedayton » 2014-Feb-Fri-20-Feb
Jerome
Retired Software Developer
Printrbot Simple operational since Xmas 2013
Printrbot Jr v 2 with alu extruder March 2014
jeromedayton
Postby RetireeJay » 2014-Feb-Sat-09-Feb
I just poured the kitty litter in the bottom of the box. Then any kind of a piece of wood or plastic sits on the kitty litter, and the spools sit on top of that. The wood or plastic does not seal against the sides of the container, so there is some air circulation. The crystal kitty litter is not dusty, so it pretty much stays put at the bottom of the container. I have plans for another use where I figure I'll just pour the kitty litter into a sock and tie it off.
