Printrbot Talk Forum • View topic - Better than canvas and finally z stability
Postby RetireeJay » 2013-Nov-Tue-13-Nov
Well, it has been a long and arduous adventure, but I think I finally have my Z axis problems solved.
As those of you who have been following my posts know, I have a Printrbot Plus (vintage January 2013) and I primarily print with nylon. Most of the time I have used a bed of canvas glued down to glass or Garolite. But I was never really completely satisified.
The problem was that I did not have good repetability for the bed-to-hot end clearance. Sometimes my prints were not smooshed down enough and would lift off at the corners or all over; other times they were too deeply embedded in the canvas and were impossible to pull off. I've broken glass plates and also broken the glue bonding canvas to glass or Garolite when the plastic was too deeply embedded.
So my first approach was to build a , so I could check and adjust my z clearance more accurately. This helped, but did not seem to solve the problem.
So then I built an . This is extremely repeatable and extremely easy to adjust (WAY better than the stock screw hidden in the back corner). This helped quite a bit, but I was still having a problem with non-repeatability of the Z position.
Finally, I took a straightedge to look at the table for the Y axis. It was warped. If I made the straightedge tangent to the table at the front end, then the straightedge was 4mm above the table at the back end. And everything changed it: heating the bed, ambient humidity, the phase of the moon...
So next I added and hold it straight (thanks, Mooselake!).
Finally, I have achieved repeatability!! :D :D
Also, I thought that maybe canvas was coarser than necessary. I originally chose canvas in part because it's fairly thick and therefore I could have glue on one side holding it down to the bed while the other side would be glue-free. But thanks to a I realized that I could use spray adhesive and therefore use thinner and flatter fabric.
So now I have cotton muslin that's a little coarser than bedsheet material (roughly equivalent to the texture of denim, but not colored). I glued it down to glass using Loctite Spray Adhesive #300 - which claims to be heat resistant as well as claiming to work on glass (the 3M sprays did not mention either of these features). I used the two-coat procedure on each surface before bonding.
It turned out that the optimum Z clearance for me using nylon to print tall, narrow objects on this fabric is zero. That is, I can't fit even a 0.05mm automotive feeler gauge under the printhead. I have my layer height set to 0.25mm and when I measure a skirt, the thickness is from 0.17 to 0.25mm - consistent with a "zero" clearance between the head and the bed when Z is zeroed. Also, I have my first layer set to a "trace width" of 400% of the other layers. So I'm pushing down a lot of plastic, but it spreads out and gets a grip. I have no raft, but I do have a Brim turned on, 5mm wide.
If I need to print an object with an extremely large footprint, I probably will give myself a little clearance so that it will be easier to remove.
I'm a Happy RetireeJay :D :D
  • 2
Re: Better than canvas and finally z stability
Postby REPRAP SQUAD » 2013-Nov-Tue-14-Nov
I'm glad to hear your z axis problems are solved. I also added aluminum channeling to the bed and sub mount which did make quite a noticable difference in keeping everything relatively flat. My z axis homing switch setup does need some work still. I recently purchased a dial gauge and originally planned on printing out your mount but if I remember correctly printrbot has a slight variation in x axis rod distance between the plus v1 and v2. Most people don't realize how important it is to have an accurate z setup. Congrats on your recent win during the battle of the z axis!
Postby RetireeJay » 2014-Jan-Wed-21-Jan
By the way, I'm also using glass with glue stick as a printing surface. One big advantage compared to cloth or Garolite is that the flat plate (the glass) can just be washed and re-used; with cloth you have to use a permanent glue to attach it to a flat substrate, which is not especially easy to do. When the cloth wears out, the whole assembly needs to be discarded. Also, the spray glues I mentioned aren't really strong enough.
Postby Gleedaniel13 » 2014-Feb-Wed-08-Feb
Gleedaniel13
Postby adamrose045 » 2014-Oct-Mon-01-Oct
GuL
adamrose045
Postby Mooselake » 2014-Oct-Mon-16-Oct
This is a good example of a spammer probe, so I'll leave it for reference.
It looks relevant, but if you read backwards it's a copy and paste from from REPRAP SQUAD's post above. In addition it's on an old topic, the poster registered and quickly posted, the user name follows a common spammer pattern, and the originating IP has been recently reported to stopforumspam.com. Not very original<sigh>.
I do have to say the spammer has good taste; Jay's dial gauge bed leveling device is a definite winner. Build and use this, and there won't be any need for automatic "bed leveling".
Postby thawkins » 2014-Oct-Mon-20-Oct
Postby Mooselake » 2014-Oct-Tue-11-Oct
They look like normal posts at first glance, recognizing them is more of a gestalt thing.
I've been dealing with them for darn near 20 years. Maybe I need more hobbies...
