Printrbot Talk Forum • View topic - PLA to ABS and Back
PLA to ABS and Back
PLA to ABS and Back
Postby healthyfatboy » 2013-Sep-Sun-21-Sep
When printing in PLA and then switching to ABS and back, I know ideally, you should clean out the hot end. Can you get by just fine if you just run a lot of filament through it at temp instead to "flush" out the other material or does it contaminate the new material to the point where it's not worth it?
Printrbot LC Kit in PrintrBOX
PB bed stabilizer, leveler, fan mount, Y belt tensioner
Printed X-axis belt tensioner, spur gears, Z stabilizer
GT2 belts and pulleys
ACME lead screws and nuts
Hotend support ()
0.4, 0.35 mm nozzles, eventually 0.2 mm
Reflectix and 3M metal tape under heated bed
Plain glass for now
healthyfatboy
PLA to ABS and Back
Re: PLA to ABS and Back
Postby RetireeJay » 2013-Sep-Mon-06-Sep
I once ran an experiment with all three materials (PLA, ABS, and Nylon). Even though I ran quite a bit of PLA through before lowering the temperature, it still jammed because of un-melted ABS (or nylon) still retained inside the hot end. The solution was to take the brass nozzle off the extruder and push through a large quantity of PLA (maybe a foot or more) to clean off the walls of the hot end so there was no more high-temp plastic in there. I could tell it was working because even though the filament going in the top was 3mm, the stuff coming out the bottom was more like 3.2 or 3.5mm - whatever the diameter of the throat is.
Postby healthyfatboy » 2013-Sep-Mon-06-Sep
So it would seem that going from PLA to ABS is okay to just flush out because of temperature melting points but going from ABS to PLA needs a clearing without the nozzle. Would that seem correct?
Hotend support ()
Plain glass for now
healthyfatboy
Postby Lemm » 2013-Sep-Mon-06-Sep
what about cleaning the nozzle with high temp pla ? I mean when switching back from abs to pla just float the hotend/nozzle with pla @ 230°C . Do you think this works ?
Printrbot Jr #11045
ACME TR10x2 Z Rod
Printrbot Jr v1 -> v2 upgrade
Lemm
Well, I think to really purge the hot end of all residue of former plastics you would need to remove the nozzle and push the new material through. But maybe that's just me. I have not done this a lot, so maybe someone with more experience should post their findings.
Postby bleeps » 2014-Jun-Mon-15-Jun
Hope it's okay to bump this and get some feedback from more experienced operators about switching back and forth. I actually have a spare Ubis that I was planning to use just for ABS. Is that the best plan of action or are there easier tricks for making the switch?
bleeps
Postby plexus » 2014-Jun-Mon-15-Jun
YMMV but when I was using Ubis I would switch materials (PLA / ABS / Nylon / HIPS / PS / PC / Laywoo) without cleaning the hot end out. I would just purge out the old material and print. I rarely had issues. When I did I can't say it was attributed to the material switching - it just appeared to be isolated issues. I've switched to E3D and do the same thing with no issues. After using the Ubis I found the Ubis has a larger melt volume in it and requires more push-through to clear it with the new material. The E3D basically only has a path the diameter of the filament straight through to the nozzle aperture. I think the Ubis has more of a volume within the nozzle where material accumulates. I think it can get trapped in there and burn and cause clogs although I have never been able to verify that. I haven't had a nozzle clog with the E3D where as with the Ubis I would get clogs from time to time.
Postby Jdublu » 2014-Jun-Tue-08-Jun
I did this last night. Was printing PLA at 205C. Received my first roll of ABS from MatterHackers (thanks guys for the FAST delivery). Set the temp at 210 and retracted the PLA. Inserted ABS, cranked temp to 215 and extruded 100mm to clean out the extruder. Cranked temp up to 225 and successfully printed my first ABS spring clip.
I needed to print the stand for my T-rex I had done the day before in PLA. Set extruder to 225 and retracted the ABS. Let it cool to 210 and reinstalled the PLA and ran another 100mm through the nozzle to flush the ABS. Then I printed the T-Rex stand and support. No jams, no problems.
Maybe I just got lucky but I've done this with HIPS too without any problems. Just don't crank the extruder up to ABS printing temps without flushing the PLA first. I try to keep it at 215 or below with PLA in the chamber.
Metal Simple
E stepper heatsink w/fan
Z axis stepper heatsink w/fan
Extruder fan
Hotbed relay fan
6"x6" Heater board
40 Amp power supply
S. Florida
Jdublu
Postby spitfirehauser » 2014-Jun-Tue-08-Jun
I have been switching from nylon to ABS and back over the last several weeks with no apparent problems either. just flush the old stuff out until the new color is "true" and switch back to the lower setting. i print the ABS around 230 and the Nylon at 250. cheers
Steve Hauser
Modified Simple 2014 kit
spitfirehauser
Postby rho-wan » 2014-Jun-Tue-11-Jun
What about the switch between ABS and Nylon and back? I expect nylon to flush out completely without issues also before extruding aBS (moreover, the temperatures are comparable).
rho-wan
