Printrbot Talk Forum • View topic - Built a nice filament drying kiln
Postby Tdeagan » 2013-Sep-Sun-22-Sep
I got sick of cursing at my foaming filament so I adapted the design from a wood drying kiln and built my self a nice filament drying kiln this weekend.
I used two 100W light bulbs wired in parallel with a dimmer. Built a 3' tall x 12" wide box out of 3/4" foil covered insulation board and foil tape. Used some wire grill and flashing to get the filament out of the direct heat of the bulbs. I put a few holes in the top and bottom to let air move.
The two 100W bulbs are overkill, but the dimmer adds a lot of flexibility. I used a temp sensor on my multimeter to set the heat at 85° C.
I stack the spools, let them bake for 4-6 hours then store them in an airtight cooler filled with heavy duty desiccant.
Tim Deagan
KC5QFG
RAMPS 1.4 w/ LCD,
Quick Change Extruders:
MIC-6 metal bed
Thingiverse Profile:
Tdeagan
Re: Built a nice filament drying kiln
Postby drawcut » 2013-Sep-Mon-17-Sep
Nice setup. It looks scorching hot with the silver reflecting the light bulbs. (just an illusion, I know :lol: )Personally I bought a food dehydrator from Harbor Freight that was about $23 on sale and modded it to give enough space for spools. No temp control though. It gets to about 140F which works OK but takes more time. I store with silica cat litter as desiccant.
drawcut
Postby plexus » 2013-Sep-Mon-18-Sep
Postby Tdeagan » 2013-Sep-Mon-20-Sep
Tim Deagan
KC5QFG
RAMPS 1.4 w/ LCD,
MIC-6 metal bed
Tdeagan
Postby RetireeJay » 2013-Sep-Mon-20-Sep
I've just been using the crystal kitty litter in a closed container. A humidity indicator inside the container says it consistently stays below 20%. Maybe it doesn't dry the filament as fast as heat, but it does work over time. Taulman ships their nylon inside closed bags with little desiccant packets so my spools go from dry to dry environment.
Postby Tdeagan » 2013-Sep-Mon-21-Sep
Tim Deagan
KC5QFG
RAMPS 1.4 w/ LCD,
MIC-6 metal bed
Tdeagan
Postby drawcut » 2013-Sep-Tue-16-Sep
drawcut
