Printrbot Talk Forum • View topic - Recomendation of 3.0mm ABS filament supplier
Postby aerogeek » 2013-Sep-Tue-11-Sep
Hi All,
Having had my hands burnt after buying a spool of blue glow in the dark ABS filamet which is too fragile and keeps clogging up the hot end I am taking a more cautious approach and asking for recomendations of suppliers of 3.0mm filament.
I am in the UK so ordering from the USA is difficult, at the moment i do not mind the colour of the filament as i am still learning the ins and outs with the printer.
Are the ones on Amazon ok to buy from?
aerogeek
Re: Recomendation of 3.0mm ABS filament supplier
Postby REPRAP SQUAD » 2013-Sep-Tue-19-Sep
I've had good experiences with makergeeks.com and they have a huge selection. There is also a guy that is a member of these forums that sells filament. I have some on the way from him so ill let you know how it turns out.
Postby aerogeek » 2013-Sep-Tue-14-Sep
OK so took a chance and bought some filament from a amazon supplier trying a repeat test print using it. Initial results are good, its lasted longer already than the glow in the dark blue filament i tried previously. Hopefully i wont have another problem with the pb+
the supplier seems to be Jet-filament.
on another note has anyone managed to get glow in the dark filament working, did you use any special settings? I am interested because i want to print off some glow in the dark stars etc for my daughters room.
aerogeek
Postby smisra1968 » 2014-Feb-Fri-09-Feb
I've had good experiences with http://www.repraper.com/ One of the few places that has clear ABS.
smisra1968
Postby ivymike1031 » 2014-Feb-Fri-13-Feb
I've purchased nearly all of my filament via amazon (using Amazon Prime) and have had no complaints that could be traced directly to the filament. I was able to print with white/glow ABS no problem, but it needed a higher temp than regular.
One complaint I have is that filament suppliers often include small unlabelled samples of different filament colors along with the order ... but I've ordered ABS and the sample turns out to be PLA! (what a mess)
ivymike1031
Layer 100 of 1234
Postby plexus » 2014-Feb-Sat-12-Feb
This account has been flag as a possible shill account. The only 4 posts they've posted advertise what appears to be their own product. the userid of the account are the names of the owners as posted on their site. We have warned them to delete all these posts by sunday or else their account will be deleted.
Shill accounts and posts will not be tolerated. if you see anything like this please flag the post and we will investigate.
thanks!
Postby ivymike1031 » 2014-Feb-Tue-09-Feb
looks like the offending post is gone from this thread.
ivymike1031
Layer 100 of 1234
Postby reepete1 » 2014-Feb-Tue-22-Feb
Here is the shop i have been ordering from. No issus with ether buying/shipping or quality (1.75 Pla only tested). Atleast for me they are fast on delivery easy to deal with. Swedish based company since i'm living in Sweden.
http://www.3dprima.com/en/
[Edit] Ah, never mind, just check the site. They only have special filament in 3.0 mm now
reepete1
Return to Material talk
