Printrbot Talk Forum • View topic - Wood glue ratio & gaffers tape question
Postby AlexC » 2013-Jun-Mon-20-Jun
This last weekend i talked to some folks about using watered down wood glue (spread then dried) as a print surface over glass but i didn't think to ask them the mix ratio of water to glue,. did a search and couldn't find anything so asking.
Also, Gaffer tape, has anyone tried it as a print surface? its a cloth based tape similar to duck tape, except its more cloth less plastic, and its made for hot studio lighting so holds up to heat very well, and is for the most part residue free. although i suspect the cloth layer will act as a thermal brier, i am still curious if anyone has tried it, once i get my bots issues sorted out i plan on trying it just to see, i imagine it will be allot better then blue painters tape but that's just a guess so i thought id ask, (search on forum comes up with 0 posts).
AlexC - Printbot LC v2, TazBot, Phoenix 1, & Prusa i3
Currently building a Kossel.
AlexC
Re: Wood glue ratio & gaffers tape question
Postby owens » 2013-Jun-Tue-08-Jun
We haven't tried glue or gaffer's tape, but the discussions I've seen around "PLA juice" always specify that it should be PVAc glue, which in the US we know as Elmer's white glue. Wood glue is different chemistry (though perhaps it would work too). You might have better luck searching for PVA or PVAc glue and PLA.
owens
Postby PxT » 2013-Jun-Tue-17-Jun
White glue (Elmer's) works great if you are printing PLA. I use it at about 5:1 ratio (water:glue) if I remember right. Should be very dilute about the appearance of milk. Just pour a small drop on the pre-heated bed, wipe it around with a paper towel and let it dry. (Only takes a few seconds on a hot bed.)
Print... part should stick very well as long as the bed is hot and pop off perfectly when cool.
Postby Lemm » 2014-Feb-Sat-15-Feb
Today I tested the wood glue. I've seen a video on youtube. And I can say it's really good stuff :D.
I painted a 1:2 wood glue : water mixture on a glass plate let it dry and printed on it. Without a heated bed all parts stick so well, no curling, no warping, without using a brim and so ...
So if you have problems with PLAA and warping try this :)
Printrbot Jr #11045
ACME TR10x2 Z Rod
Printrbot Jr v1 -> v2 upgrade
Lemm
Postby janggeungulk » 2014-Feb-Mon-03-Feb
We tried only Elmax wood glue adhesive it is useful for both internal and external usage.
janggeungulk
