Printrbot Talk Forum • View topic - wooden filament
wooden filament
wooden filament
Postby ken schmitt » 2012-Sep-Thu-08-Sep
"This wood filament LAYWOO-D3 is a wood/polymer composite - the filament contains recycled wood and harmless binding polymers. The material has similar thermal durability as PLA and can be printed between 175°C and 250°C. "After printing it looks like wood and smells like wood." Depending on the temperature you can even print wooden-like objects with annual rings. At 180°C, the prints has a light color, at 245°C it becomes darker. Afterwards the printed objects can be cut, grinded or painted. "
Where I post my interesting 3d Printing links
ken schmitt
wooden filament
Re: wooden filament
Postby PxT » 2012-Sep-Thu-11-Sep
Wow. WANT!
Re: wooden filament
Postby Mooselake » 2012-Sep-Thu-14-Sep
Re: wooden filament
Postby holmes4 » 2012-Sep-Thu-15-Sep
This is fabulous. I'll definitely want some once it's available.
Steve
PB+ Backer 1402
holmes4
Bowden extruder
Re: wooden filament
Postby jkocurek » 2012-Sep-Sat-19-Sep
There is another way to do it. There is a German company which makes a plastic from lignin.
http://blogs.howstuffworks.com/2010/07/ ... like-wood/
No reason which filament cannot be made from it.
jkocurek
Re: wooden filament
Postby scantrontb » 2012-Sep-Sun-00-Sep
woot woot!... now i can make my own set of custom designed Lincoln Logs!... yeah!
PB+ #786
scantrontb
Can update firmware
Re: wooden filament
Postby wasty » 2012-Sep-Fri-09-Sep
i just ordered 2x 0.25kg from www.grrf.de...
I am curious about the the prints :-)
wasty
Re: wooden filament
Postby PxT » 2012-Sep-Fri-11-Sep
Please post your results. I would like to get some but with shipping to the US it is about $115 per kilo which is a bit much.
Re: wooden filament
Postby plexus » 2012-Sep-Fri-12-Sep
I just ordered 1kg of the wood filament. shipping was 20 euro and that also included a spool of PS filament too! and on checkout for some reason the prices were discounted down to 15 euro per 0.25kg spool of the wood. total for 4x 0.25kg wood and 1x 0.75kg PS with shipping converted to canadian was $138.
UPDATE: I emailed them about lead time. they said 3-5 weeks from order time to delivery. i can wait for my wood.
Re: wooden filament
Postby vgvallee » 2012-Oct-Wed-17-Oct
It looks like a fun material. Make sure to let us know the results using it.
vgvallee
Re: wooden filament
Postby wasty » 2012-Oct-Mon-15-Oct
got mine today.
The feeling when you hold it in your hand is nice. something between saw dust, cork and wood.
But as i read somewhere (i think it was thingiverse) it leaks like hell. Like when letting a hot glue gun become to hot...
Temperature control is tricky. i printed 210°C and 90° Bed. it was a bit dark as burned toast on the bed layer. :-)
Ah yes, and i didn't spend much time on settings... :D
wasty
Re: wooden filament
Postby mdfast1 » 2012-Oct-Tue-14-Oct
Mmm looks like toasted wheat cereal.
UBIS 13
Printrbot LC+ - Operational
Printrbot Original- Donated
GT2 - 20 Tooth Pulleys
GT2 Belts
Brass Threaded Rods
Spur Gears from drawcut
.35mm nozzle
mdfast1
Re: wooden filament
Postby SolidVis » 2012-Oct-Tue-18-Oct
SolidVis
Re: wooden filament
Postby plexus » 2012-Oct-Wed-13-Oct
I got the wood filament today. the label on the bag has "cherry" checked off and "pine" not checked. on their the pictures show what I think is pine and thats what i wanted. not something darker. did you get cherry or pine?
FYI I bought 1kg. with shipping split between the wood and some PS filament, it comes out to about $90CAD/kg for the wood filament.
Re: wooden filament
Postby Marcus » 2012-Oct-Wed-14-Oct
Marcus
Re: wooden filament
Postby plexus » 2012-Oct-Wed-20-Oct
Re: wooden filament
Postby plexus » 2012-Nov-Thu-01-Nov
ok how do you use this stuff? i tried printing a small thing and it was very soft moving up the layers. so soft that it moves the whole object around when printing. i was using extruder temps 195-230C and bed at 80C.
Re: wooden filament
Postby jkocurek » 2012-Nov-Sun-08-Nov
It was discounted down because they backed out the VAT because it was exported.
jkocurek
Re: wooden filament
Postby Mooselake » 2012-Nov-Tue-12-Nov
Interesting for those of you who've bought this filament, makes it look like woodgrain by varying the temp while printing.
No, I don't use (it's on the list) or print with wood, and haven't tried it.
Re: wooden filament
Postby ken schmitt » 2012-Nov-Tue-13-Nov
ken schmitt
Re: wooden filament
Postby barretzhang » 2012-Dec-Wed-07-Dec
that's great
we mainly provide the ABS,pla filament for 3D printer,with multi-diameter(3mm,2mm,1.75mm),and wo could supplied the color by your request.
Email:ecobiomaterial@gmail.com
skype:barretzhang
barretzhang
Re: wooden filament
Postby notwebsafe » 2013-Jan-Tue-03-Jan
Curious whether others have been experimenting with this on the PB Jr. I just got some of the cherry (the pine is out). I like the appearance of the material, but it's definitely trickier to print with.
Unlike the blog post linked above (which recommends temps over 205), I'm finding that 190C seems to be a sweet spot--anything higher and it seems to extrude/leak too much, and I haven't gotten any clogging at that temperature.
That said, it doesn't seem to shape as accurately as PLA--fine details get lost in the perimeters. Also, my infills are messier--the strings often "pull up" and don't connect to the perimeters at the ends. Small top layers are a mess too--I tried printing out a small gargoyle, and it mostly did fine until the top small layers (where surfaces converged to points), which turned into spaghetti (even with "slow down small layers" turned on). Bigger prints with larger features seem to work better.
I checked my extrusion calibration and the E steps are a bit low, but I'm assuming that because it's so "leaky" that's probably not a bad thing...the strings that it prints seem a bit thick as it is.
notwebsafe
Re: wooden filament
Postby plexus » 2013-Jan-Tue-13-Jan
I've been experimenting with with the LAY-WOO-D3 wood filament lately. the first batch I bought, 750g, was much darker than the second batch of 2kg I bought. one thing I will advise is do not use anything smaller than a 0.5mm nozzle with the wood filament. I put on a 0.35mm nozzle and was merrily printing away with ABS and PLA. then i printed a small wood thing. after that I was getting horrible infill. the only thing I could think of was an clogged nozzle. so i cleaned out the nozzle by soaking in acetone and using a pick. there was a fair amount of what appeared to be almost black wood filament jammed in there. after i cleaned it out i tried again with the wood filament. disaster. the filament wouldn't extrude and it was a real chore to clean it out.
but when I have printed with a 0.5mm nozzle it worked pretty well and there was no sign of clogging. so i think 0.35mm is too narrow for the wood particles in the filament.
Re: wooden filament
Postby notwebsafe » 2013-Jan-Thu-23-Jan
I also found that setting retraction to 2mm instead of 1mm seems to improve the leakage a bit during prints.
notwebsafe
Re: wooden filament
Postby plexus » 2013-Feb-Tue-12-Feb
I am having trouble with printing with LAYWOO-D3. the biggest issue is nozzle clog. i am using a 0.5mm nozzle with it and I keep getting clogs. does anyone know a) what solvent works with LAYWOO-D3, b) the best way to clear out a clog (assuming we don't know what solvent works - acetone barely works) and c) how to prevent clogs in the future.
the stuff is quite expensive, at about $100/kg and i'd like to stop wasting it. if its not possible i would prefer to sell it to someone who can better print with it so im not wasting it.
I have started about 4 prints of a cube object 60x60x60mm approx. i barely get 1/2 way when i run into trouble, either clogs or the filament snaps because it comes on "air spools" which do not unspool very well, and the filament is very brittle.
Re: wooden filament
Postby plexus » 2013-Feb-Wed-15-Feb
UPDATE: I was able to print a full "thing" with the wood filament. really it was just a matter of the hot end not clogging and the filament not breaking, two things which have been plaguing my attempts to use LAYWOO-D3. it worked out really nice. I printed using 0.5mm layers which may have helped because there would be more material flowing. before I was printing with 0.3mm layers.
It works out really nice. I wish Repetier-host would support a couple ideas I posted on their github. one is a graphical interface that allows creating both a hot bed and extruder temp profile. basically you can use it to control the temps over the duration of the print. this would be useful with the wood filament to create wood grain profiles! I think skeinforge can do this but i'd like to see it as part of Repetier-host.
Re: wooden filament
Postby halley » 2013-Feb-Wed-15-Feb
halley
Re: wooden filament
Postby plexus » 2013-Feb-Wed-16-Feb
Re: wooden filament
Postby halley » 2013-Feb-Wed-21-Feb
halley
Re: wooden filament
Postby plexus » 2013-Feb-Wed-22-Feb
Re: wooden filament
Postby halley » 2013-Feb-Thu-06-Feb
http://i.imgur.com/kmPmi1H.png
It didn't need chmod 777. Full path required (as the Slic3r pages instructed me). Never use folder names or filenames with spaces if you're going to work with them with scripts.
halley
Re: wooden filament
Postby plexus » 2013-Feb-Thu-21-Feb
Re: wooden filament
Postby halley » 2013-Feb-Thu-22-Feb
No, I haven't tested laywood at all, so I didn't know if it was going to drool or not, and using M104 instead of M109 is just fine.
halley
Re: wooden filament
Postby plexus » 2013-Feb-Thu-22-Feb
yes, if you change it to M104, then it works. i am doing a test print now. the temps are fluctuating. it will be interesting to see how the computed temps and the actual temp interact with each other.
UPDATE: did a couple test prints. its challenging. using the wood filament is a bit of a challenge. especially if you are printing fast and/or small. bigger things, ok. my test pentahedron was a little too small but it gave me a sense of the way it works. i think the temps needed to be reduced. and perhaps a wider amplitude. i think that youd have to adjust the "geometry" of the computation depending on what you are printing, the size of it.
Here are some temp graphs (dim line is set temp, thicker line is actual temp). i will post pics soon.
Re: wooden filament
Postby scantrontb » 2013-Feb-Fri-13-Feb
those are actually pretty cool pics... how did you do that? and just to be thorough, what are the other color coded lines?
PB+ #786
scantrontb
Can update firmware
Re: wooden filament
Postby plexus » 2013-Feb-Fri-14-Feb
Re: wooden filament
Postby scantrontb » 2013-Feb-Fri-15-Feb
PB+ #786
scantrontb
Can update firmware
Re: wooden filament
Postby liuyelian » 2013-Jun-Fri-03-Jun
They say on Thingiverse it'll be available for sale soon, not sure if that's the Kickstarter "soon".
_____________________________________________________________________
? Born on 28.10.08 ?
avvie - sunakonakahara
siggie - artosan
How are you!I'm new!
liuyelian
Wooden printed zelda crest of hyrule
Postby mothy » 2013-Aug-Sun-19-Aug
Here is a thing I printed with a 10m sample of laywoo-d3 check it out.
Started at 185, but was jamming the extruder, luckily I saved it, cranked it up to 210 after the first few layers, Its not perfect but i like how forgiving this filament is, looks like wood!
mothy
Re: wooden filament
Postby EvaMMF » 2013-Oct-Fri-05-Oct
Bookend printed in laywood at work. Print went ok, except did burn on the 'ears' (I guess owls arent suppose to have ears anyway!). I'm not massively keen on the finish but nice to try out a new filament.
EvaMMF
Re: wooden filament
Postby plexus » 2013-Oct-Fri-15-Oct
Re: wooden filament
Postby EvaMMF » 2014-Jan-Wed-07-Jan
inspired by
STL file can be downloaded for free here
:D :D :D
EvaMMF
