Filament Recommendation for Compression
Postby pkreitler » 2016-Nov-Wed-14-Nov
Hi. I am trying to determine the best filament material to use for a part under heavy compression load. The part is essentially a thin washer about 1/32-inch (0.8 mm) thick. The part acts as a spacer where a thin walled tube sits atop a flat surface. There is a dynamic load on the tube occasionally that causes it to move slightly on the washer. I printed the part using ABS with 100% infill. Over time the ABS part compressed under the weight of the tube. I would like to find a material that won't deform over time, but also won't crack when the tube moves. Any thoughts?
Thanks.
pkreitler
Re: Filament Recommendation for Compression
Postby musk » 2016-Nov-Wed-19-Nov
pkreitler wrote:Hi. I am trying to determine the best filament material to use for a part under heavy compression load. The part is essentially a thin washer about 1/32-inch (0.8 mm) thick. The part acts as a spacer where a thin walled tube sits atop a flat surface. There is a dynamic load on the tube occasionally that causes it to move slightly on the washer. I printed the part using ABS with 100% infill. Over time the ABS part compressed under the weight of the tube. I would like to find a material that won't deform over time, but also won't crack when the tube moves. Any thoughts?
Thanks.
Not sure how precise you need this, but I'd try using Ninjaflex (or semiflex) and making it thick enough to account for the amount of squish under full load. Even though it's flexible, it's insanely durable (almost indestructible) and doesn't seem to easily deform in permanent ways.
Printrbot Metal Plus (2x)
Printrbot Simple Metal (2x)
musk
Postby RetireeJay » 2016-Nov-Wed-20-Nov
Nylon is extremely tough and much less elastic than Ninjaflex. viewtopic.php?f=74&t=5286&p=34498
One downside is that nylon is a bit sensitive to water & humidity - it can swell and/or warp just a bit (not too bad).
Also, for 3D printing, it's not really very good for printing things that have lots of on/off moves because it oozes - but it should be fine for printing a washer. You can print it on 70C heated glass (or presumably other materials) if you use glue stick to prep the surface.
How many washers do you need to print? If you only need a few meters of nylon and if you use "3mm" filament, then PM me and I can send you some (I have a stock that I rarely use any more).
Postby WayTooManyHobbies » 2016-Nov-Thu-05-Nov
Plastics in general exhibit significant creep under load - on other words, they don't maintain their shape over time. Without knowing more about the use of the part it's difficult to make a good recommendation, but I'd suggest that 3D printed plastic is probably not the best choice.
WayTooManyHobbies
