Printrbot Talk Forum • View topic - 3M Scotch Blue "Delicate Surfaces" Tape: Do Not Try!
Postby ktfergus » 2016-Feb-Mon-22-Feb
I just wanted to post this so that no one makes the same dumb mistake I did. Somehow, when I last reordered tape I ended up ordering the version, rather than the tried and true .
The "delicate surface" tape does not hold to the bed at all & it's super thin (we're talking a few angstroms). Plus, it's more expensive than the standard tape! Gah, I feel like a grade a moron & i'm out $9--hopefully I can stop anyone else from making the same mistake.
-Kelly
PrintrBot Model: 1403 (Simple Metal Assembled) ::
ktfergus
Re: 3M Scotch Blue "Delicate Surfaces" Tape: Do Not Try!
Postby JonS » 2016-Feb-Tue-01-Feb
Thanks for the providing the warning.
I suspect it's rather thicker than a few Angstoms though. A sheet of graphene (mono-layer of carbon atoms) is about that!
Printrbot Metal Plus with:
- Dual Gear Head extruders
- Heated bed
- PEI print bed film
JonS
Return to Material talk
