3d scanning services and hacks
Postby ken schmitt » 2011-Dec-Fri-21-Dec
you can get the point cloud.
http://www.shapeshot.com/index.php
ken schmitt
Re: 3d scanning services and hacks
Postby Rosebug » 2011-Dec-Sat-13-Dec
I just tried this, thanks to a Maddox blog.
123Dcatch, It is FREE!
http://www.123dapp.com/catch
I have a Sculpture I made of Abe Lincoln in Sculpey and then painted.
I put him on a bar stool under a sky light.
I took about 45 images Starting in front, looking up at his chin, then spiraled around 2 times, ending up looking down on his head.
You upload the pics and the "cloud" does all the work. Creates the entire room.
Then I isolated the head and sent out to the cloud for a med then Hi res version.
I Exported the .obj and imported into Maya.
They even provide a UV map! Pretty cool
Will definitely print it even if texture is doing alot for model.
Real sculpture:
123D Catch render:
Backer #193
Tucson Arizona
Purpose: Toy design
Maya for modeling
ABS
Rosebug
Postby ken schmitt » 2011-Dec-Sat-19-Dec
deep links dont always work, you might stick it into a drop box public area and link it there.
its difficult to know, as the image is cached locally and doesn't indicate a broken link.
all we see is blue question marks.
ken schmitt
Postby holmes4 » 2011-Dec-Sat-19-Dec
I can't get the app to download - clicking on the download button just leads me in circles.
Steve
PB+ Backer 1402
holmes4
Bowden extruder
try using a different browser. I think I had the same problem, I believe opera worked.
ken schmitt
Postby Rosebug » 2011-Dec-Sun-01-Dec
Posted pics on web site.
Images showed up in Previews
Sorry but here are the copy n pastes...
Real:
https://5154248316839016887-a-180274477 ... edirects=0
123D Catch
Backer #193
Tucson Arizona
Purpose: Toy design
Maya for modeling
ABS
Rosebug
Postby eddiema » 2011-Dec-Sun-04-Dec
Rosebug wrote:I took about 45 images Starting in front, looking up at his chin, then spiraled around 2 times, ending up looking down on his head.
Have you tried using just a few images?
Can it do anything with just a stereo pair? Obviously you won't get a full 3d object but do you get a surface at all?
eddiema
Aluminum coupler brain
Postby Rosebug » 2011-Dec-Sun-13-Dec
Stereo pair is just not how 123D Catch works.
It needs the background landmarks to plot position of objects. (so no lazy susan)
First time I took 30 pic and spiraled only once, did not turn out nearly as good.
Patches missing on top of head n under chin.
So 2nd time battery running out or would taken more.
Also put objects in background for software to work with.
Some people take movies and load the individual images. The more images the better.
Going to do a stuffed animal I made next.
Backer #193
Tucson Arizona
Purpose: Toy design
Maya for modeling
ABS
Rosebug
Postby ken schmitt » 2011-Dec-Mon-18-Dec
I guess a way to increase the general accuracy of the 123D method is to then do a rudimentary scan with something like a dave's, and use that to match up with the 123D to make the scale fit.
I have awful luck with dave's. I get hundreds of thousands of points and a general shape, but nothing I have been able to use, and certainly not a complete 360 scan. but what it did scan, it got very right.
ken schmitt
Postby ken schmitt » 2012-Jan-Mon-20-Jan
adobe 123d catch
its the second one.
http://www.123dapp.com/create
here is a video that is an ideal scan; its still kinda blobby, think of the shape colorless, but its very good.
http://youtu.be/oUSNlZ4A0x4
ken schmitt
Postby Thompson » 2012-Jan-Tue-09-Jan
So, is it possible to make a model of something from a video on youtube?
If I understand correctly, you can not because it usually does not go around the back of the object, so you would only get the front.
Backer number 1,088.
Thompson
Postby ken schmitt » 2012-Jan-Tue-19-Jan
you missed the point, but if the pictures in the video were the ones used, yes.. if they are clean enough.
the pictures used were at least 1920 wide.. the frame size on youtube, probably not.
ken schmitt
Postby Thompson » 2012-Jan-Fri-20-Jan
I was referring to this Ken, but thanks for the answer :D I can't wait to try it out!
Thompson
Postby scantrontb » 2012-Jan-Sat-01-Jan
ken schmitt wrote:you can get the point cloud.
of HER! cool! :P
PB+ #786
scantrontb
Can update firmware
Postby ken schmitt » 2012-Jan-Sat-16-Jan
http://pgrammetry.com/forum/index.php
http://www.doc.ic.ac.uk/~ajd/
http://www.thingiverse.com/thing:8885
quoting travis:
You should check this out. http://pgrammetry.com/forum/index.php
It's a website with forums dedicated to photogrammetry (2d to 3d photomodeling). There are a number of links to various programs, webservices (like my3dscanner.com), and experimental work.
At least one of them is open-source, http://pgrammetry.com/forum/viewtopic.php?f=35&t=137
it has anything and everything on photo to 3d conversion.
ken schmitt
Postby ken schmitt » 2012-Jan-Sat-17-Jan
ken schmitt
Postby Thompson » 2012-Jan-Sun-23-Jan
ken schmitt wrote:.. that's kinda creepy..
I agree.
Thompson
Postby ken schmitt » 2012-Jan-Sat-20-Jan
Anyone have any ideas on probe scanning?
basically, a sensor, or a rod with a switch on the top hangs from the head. you could let a probe scanner get a cloud precisely off of the print platform.
http://www.cadcamcadcam.com/contactprobe.aspx
http://www.imsrv.com/deskcnc/probe.htm
the stats on this particular sensor that is $250
The TP-100 contact probe is a 3/8 shank ( or 10mm optional ), 5 way mechanical contact scanning device with a 2mm ( .0787 in) diameter ruby tip. It is used with CNC milling and CNC routing style machines to digitize surface and contour data. When used as a probe the shank is mounted in a spindle collet or chuck or other holder parallel to the spindle axis. The probe also includes a flat base and tip which can be used to convert the probe into a table based tool measurement instrument. Tip stylus extensions are available in 20, 30, 60 , and 90 mm lengths. 1mm, 3mm, and 4mm diameter, ruby tips styli are also available.
When used with Mach3, a free plugin is available to collect a raw point cloud data set from a 3D surface. There are also g-code based routines to collect 2D contour data. Mach3 can also use the tool setter base and flat stylus for tool setting.
When used with DeskCNC, a probed surface is filtered, smoothed, reverse compensated for the probe tip radius, and saved as an .STL CAD file. The 3D surface machining CAM in DeskCNC can make minor edits to the surface and will produce 3D surfacing toolpaths to duplicate the scanned part. DeskCNC has automated routines to measure and record tool lengths when the probe is used as a tool setter. The photo below is a workpiece created from the scan of the leopard above.
This probe will work with CNC controllers that interface to a probing input from a switched contact. This includes DeskCNC, Mach3, TurboCNC, EMC and many other programs/controllers.
ken schmitt
Postby ken schmitt » 2012-Jan-Sat-21-Jan
and the milk scanner. / fluid scanner
http://www.instructables.com/id/Milkscanner-V1.0/
http://milkscanner.moviesandbox.net/
This project started out as the Milkscanner (as described on instructables). The basic idea behind this process is that you can capture the silhouette of an object easily when it is surrounded by a high contrast fluid, such as milk or ink.
When lowering the object into the fluid, the silhouette changes gradually, as the fluid obstructs more and more of the objects shape. By capturing the silhouette of an object at different stages of submersion, one can generate slices, that, if properly stacked together, can be interpreted as 3D data.
ken schmitt
Postby ken schmitt » 2012-Jan-Sun-11-Jan
its a multi page description of several technologies. i would suggest it as a blanket 'what is this' site to send someone to.
http://www.dirdim.com/lm_everything.htm
ken schmitt
Postby ken schmitt » 2012-Feb-Wed-09-Feb
Is anyone using a xbox kinect to scan with?
http://www.thingiverse.com/search?q=kinect&sa=Search
ken schmitt
Postby TheGrum » 2012-Feb-Wed-11-Feb
Yes, multiple people are doing things with the Kinect to produce point cloud data.
Here is a link from the MakerBot blog, third item is a Kinect to STL program available on GitHub:
http://www.makerbot.com/blog/2012/01/09 ... to-create/
Here's an Ultimaker guide to setting up an OSX box to use the method mentioned above:
http://wiki.ultimaker.com/Kinect_2_STL
Here's a video and link to a different kinect 3d scanner on GitHub:
http://www.youtube.com/watch?v=ke9r70QpqQg
Here is another video tutorial on going from Kinect to Blender:
http://www.youtube.com/watch?v=08PUC9NA ... re=related
TheGrum
Postby Marcus » 2012-Feb-Wed-16-Feb
I managed to find a KInect cheap at the ebay classifieds, but that [insert synonym for a dislikable person] first agreed but then sold it to someone else (probably reaized he could sell it for more...).
Oh well. Can't wait to get one, but right now I don't need another expensive toy :-)
I'll probably use a VGA pocket projector and a webcam - anyone has any info on results (and software used) with that? The big plus is that I have those available and would not need to buy more stuff.
Marcus
Postby TheGrum » 2012-Feb-Wed-18-Feb
Sure.
There's FlexScan3d:
http://blog.makezine.com/2009/02/17/3d- ... -and-proj/
But it is not free, nor even an end-user solution (i.e. 'request a quote,' not, 'here's the price').
MakerBot has a 3d scanning DIY pattern up (this is not a kit you purchase, just instructions on what to download and put together) that uses a projector and webcam:
http://wiki.makerbot.com/3d-scanner
Hackaday has another here:
http://hackaday.com/2011/10/08/structur ... d-scanner/
Both appear to use the same libraries, a ThreePhase decoder application, the PeasyCam library, and the ControlP5 library.
There is a similar set of solutions for working with a webcam and a laser-line projector, and on one of the pages about it, someone claims that the software used for it, David 3D, can also be used with a projector (and likewise claims that the results with a projector are both better (which surprised me) and easier (which did not) with the projector than with the laser.
The David 3d software is here, and the page does confirm that it also now offers a structured light (i.e. projector based) solution:
http://www.david-laserscanner.com/
This one is a pay solution, €329 (EUR), but can save straight to an STL (the free solution above, going by the Makerbot page, gives you a point cloud, then you need to use Blender or MeshLab or the like to create a surface model and produce an STL).
I hope that helps, Marcus!
TheGrum
Postby Marcus » 2012-Feb-Wed-18-Feb
Thanks! I've seen the hackaday & makerbot projects, but I was unaware David was able to work with projectors as well...
I guess I'dd go with the free route.
The only software I thought of buying once was vi3dim.com, but the lack of updates and the strict hardware requirements to get it work (tried two computers, one should have worked but it kept crashing) put me off.
I know there are other picture/video to 3d model solutions, but at leas the ones I know are either very expensive or cloud based... Perhaps it's just me, but I'dd like a solution that does not depend on some internet service so it is asured that it will work even if the company discontinues the product.
Marcus
Postby ken schmitt » 2012-Feb-Wed-19-Feb
I just purchased a new one, which I will have in a week.
my laser scanner tinkerings have been more frustration than success... i get 200k points that arn't where they should be. :P
I see much progress with the kinetics.
I have tinkered with dave, it is the reason i got a kinetics.
I am not concerned so much about its absolute precision, as i will be scanning things that dont need that precision: rooms, and objects I am designing shelling for.
ken schmitt
Postby ken schmitt » 2012-Feb-Wed-21-Feb
I have a low quality, low resolution projector ive tinkered with Dave with, and in spite of its inadequacies, it has been better in some things than the laser on the ticking apple kitchen timer has been.
An uncalibrated depth scan RGB can be an interesting piece of art, save your better ones.
ken schmitt
Postby ken schmitt » 2012-Feb-Thu-08-Feb
http://www.vi3dim.com/
The method proposed by Vi3Dim requires a simple camera. Rotating the object in front of the camera lens, or moving the camera around the object enables the software to reconstruct the object’s surface mesh, within attached texture from the sequence of the collected frames.
not bad for $20.
ken schmitt
Postby Marcus » 2012-Feb-Thu-08-Feb
Yeah that was the one I mentoned. BUt the software works on few systems (at least none of mine, as the only one having a gpu & enough graphic memory does not work with it properly).
If the person would develop it further (pro version anounced for a year? Longer?) perhaps it would rock.
Marcus
Postby TheGrum » 2012-Feb-Thu-11-Feb
Just an FYI, Sean Bires posted publicly on G+ complaining about the
'bullsh---y' results from scanning with the Kinect, and that he was going to try the David method of laser scanning in hopes of better results.
https://plus.google.com/115837430604346 ... 2xaSFMaKZk
A bit later he posted: "Ugh, optical laser scanning kinda sucks too... it's like your object has to be caked in diffuse white in order to scan. Blacks, specularity, and subsurface scattering ruins it, so practically any anime figure is unscannable, unless you're willing to irreversibly destroy it with white primer."
Don't know if he's tried the SLS approach yet.
TheGrum
Postby ken schmitt » 2012-Feb-Thu-19-Feb
you can usually pack the object in some form of hardening something or other, be it sand, polyform, play dough.. fill the gaps, pull it apart.. then either cast the mold, or scan the mold.. either way.
ken schmitt
Postby ken schmitt » 2012-Feb-Sat-15-Feb
I just got a kinect. I'm looking for simple and fast scanning software for it.
http://www.brekel.com/
http://labs.manctl.com/rgbdemo/
http://www.microsoft.com/download/en/details.aspx?id=27876
http://manctl.com/index.html
I like this thing, It will probably be my primary scanner.
ken schmitt
Postby ken schmitt » 2012-Feb-Sun-11-Feb
Hyer3d, similar to 123design
http://www.hypr3d.com/
ken schmitt
Postby ken schmitt » 2012-Feb-Sun-12-Feb
3Dsom , another picture to object converter.
http://www.3dsom.com/index.html
ken schmitt
Postby ken schmitt » 2012-Feb-Sun-20-Feb
progress..but nothing successful yet.
the reflective black surface of my camera has thrown off every attempt at scanning I've done so far.
this is a infrared frame from the kinect,
I DID get a stream with 310 million vertices... but that is a bit much, so i need to try it again.
ken schmitt
Re: 3d scanning services and hacks -reconstructme
http://blog.ponoko.com/2012/02/23/real-time-kinect-3d-scanning-with-reconstructme/?utm_source=feedburner&utm_medium=feed&utm_campaign=Feed%3A+Ponoko+%28Ponoko%29&utm_content=FaceBook
http://reconstructme.net/
ReconstructMe is a software tool for Windows that uses the Microsoft Kinect (or Asus Xtion PRO LIVE) to capture 3D models in real-time. The software given to testers originally just displayed device info, and reconstructed models from existing data, but now it has the all of the basic features from beginning to end.
Even though it doesn’t have a GUI yet, ReconstructMe is very easy to use, and produces an STL file that is almost immediately ready to print. When scanning myself, I only had to execute the basic repair script in netfabb Studio (to close holes in the mesh), and then crop out the portions that I didn’t want to print.
ken schmitt
Postby scantrontb » 2012-Feb-Thu-20-Feb
i got an app for my iPod called "trimensional" it still needs some work (a lot!) to get the output correct, but it's a start. basically you go to a dark place for best results, and it takes pictures with the built in camera facing you, at the same time it shines the view screen in different locations, and combines the different shots into a 3d image. the only major problem is that any shiny surfaces like your eyes reflect back more light so they appear to be closer to the camera... it ends up looking like you have daggers in your eyes!...
PB+ #786
scantrontb
Can update firmware
Postby mdfast1 » 2012-Feb-Mon-13-Feb
Doesn't look too bad. I'm going to give this a shot tonight. My friend is trying to model a helicopter blade (Blade 120 SR) and having issues getting the curve into solid works. This software or 123D by Adobe might help us out. I'm not sure how it will work for smaller things like the blade though.
UBIS 13
Printrbot LC+ - Operational
Printrbot Original- Donated
GT2 - 20 Tooth Pulleys
GT2 Belts
Brass Threaded Rods
Spur Gears from drawcut
.35mm nozzle
mdfast1
Postby ken schmitt » 2012-Feb-Mon-22-Feb
This reconstructme is going to take a bit of practice to get anything usable out of it.. at least, with smaller items.
ken schmitt
Postby Marcus » 2012-Feb-Mon-22-Feb
I don't know what it is, but it does not look apropriate :-)
Marcus
its a camera on a tripod, apparently all made of play dough.
ken schmitt
Postby mdfast1 » 2012-Feb-Mon-23-Feb
We tried some scanning with David Laser Tools and a Laser Line. Less than ideal output. I would say it was about 20% usable. Lots of cleanup would be needed. It looks like ReconstructMe isn't much better.
UBIS 13
GT2 Belts
Brass Threaded Rods
.35mm nozzle
mdfast1
Postby ken schmitt » 2012-Feb-Tue-08-Feb
http://code.google.com/p/parsley/
parsley, similar to dave's. its not as advanced.
ken schmitt
Postby mdfast1 » 2012-Feb-Tue-09-Feb
Pretty cool. Looks like it gets better results than we did with David Laser Scan, however, what is the next step to easily blend all sides into a 3D model and make it solid with printable faces. Is there some software that makes this cleanup process easier?
UBIS 13
GT2 Belts
Brass Threaded Rods
.35mm nozzle
mdfast1
Postby ken schmitt » 2012-Feb-Tue-10-Feb
meshlab
ken schmitt
Postby Marcus » 2012-Feb-Tue-10-Feb
Neat. Any idea if there's still progress?
I still would like something as simple as vi3dim, is there anything like it as open source project?
//EDIT
Wow, vi3dim actually has updates, going to read throug it :)
Marcus
Postby mdfast1 » 2012-Feb-Tue-11-Feb
It looks like the creator of Parsley is actually part of the ReconstructMe development team. I would guess that he has stopped working on the Parsley application, though I'm not sure.
UBIS 13
GT2 Belts
Brass Threaded Rods
.35mm nozzle
mdfast1
Postby Marcus » 2012-Feb-Tue-11-Feb
I think the laser scanner and/or vi3dim will be better for scanning smaller objects, I hope development will speed up a little.
Marcus
Postby TheGrum » 2012-Feb-Tue-14-Feb
This Thing is a comparison of a scan using ReconstructMe and one taken using Spinscan (a laser scanner):
http://www.thingiverse.com/thing:18146
Spinscan:
http://www.thingiverse.com/thing:9972
TheGrum
Postby Marcus » 2012-Feb-Tue-16-Feb
I totally forgot about Spinscan : shock:
Very nice.
I browsed the github and Thingiverse page, any info on hardware requirements (recommended hardware, camera, laser line etc.)?
Marcus
Postby mdfast1 » 2012-Feb-Tue-16-Feb
Spinscan looks like it gives some really promising results. I just want to put a little less effort into scanning, It just doesn't seem like that will be possible.
UBIS 13
GT2 Belts
Brass Threaded Rods
.35mm nozzle
mdfast1
Postby BigBoxDriver » 2012-Mar-Sun-22-Mar
A new link ..
http://hackaday.com/2012/03/03/very-eas ... nstructme/
also about the reconstructMe ...
regards
peb
BigBoxDriver
Postby TheGrum » 2012-Mar-Mon-14-Mar
With respect to obtaining a line-laser for something like the spin-scan, this page gives examples of simple mechanisms for converting a laser pointer into a line laser:
http://www.3ders.org/articles/20120305- ... nning.html
TheGrum
Postby ken schmitt » 2012-Mar-Wed-17-Mar
3Dify, kinect scanner. in beta.
http://www.matherix.com/homepage.html
ken schmitt
Postby ken schmitt » 2012-Mar-Sat-20-Mar
better.. i still hadn't gotten a scan I'm trying for yet.
ken schmitt
Postby ken schmitt » 2012-Mar-Thu-19-Mar
this article is actually more substantive than the website, so far.. but its got promise.
http://venturebeat.com/2012/03/27/matterport-3d-scanner/
and why is that a matterport, its clearly a kinect http://www.youtube.com/watch?v=3-fgKUuwUB4
this looks nice though
http://angel.co/matterport
http://3dcapture.it/
ken schmitt
Postby ken schmitt » 2012-May-Tue-11-May
reconstructme has added multi scan volume stitching and some other features:
http://reconstructme.net/2012/05/08/reconstructme-0-4-0-370-released/
ken schmitt
Postby tgfisher » 2012-May-Tue-01-May
Ken, what kind of kinect are you using for the reconstructMe? The Kinect for windows has a 'near mode' that (I believe) the xbox version does not. Facial scans come out pretty nice with the Kinect for Windows. I haven't tried adding reading glasses to it yet, but it is still not bad at all.
Cheers,
Ted
tgfisher
Postby ken schmitt » 2012-May-Tue-06-May
its not the windows model
its the one that comes with the power supply.
ken schmitt
Postby tgfisher » 2012-May-Tue-16-May
Sample image obtained from a Kinect for windows, and reconstructMe. I just sat the subject in a swivel chair and rotated it back and forth a couple times.
tgfisher
Postby ken schmitt » 2012-May-Wed-17-May
nice.. try again with glases, and sit about a foot from it. your resolution will be much higher.
ken schmitt
Postby ken schmitt » 2012-Jun-Thu-21-Jun
its gotten better.
ken schmitt
Postby 3dcreationsllc » 2012-Jul-Tue-09-Jul
Don't scan buildings with windows on a sunny day using 123D Catch...
http://3dcreationsllc.com/2012/07/24/sc ... 23d-catch/
3dcreationsllc
Postby Marcus » 2012-Oct-Wed-14-Oct
ken schmitt wrote:http://www.vi3dim.com/
its gotten better.
And more expensive :(
Marcus
Postby ken schmitt » 2012-Oct-Wed-16-Oct
its gotten better.
"Buy it now for only $395 and save $100
You will receive an email with license code usually within 24 to 48 hours.
Read this tutorial before using the software."
yikes. my kinect and glasses still cost less than that.
ken schmitt
Postby Marcus » 2012-Nov-Tue-13-Nov
I received my Kinect a few days ago, and it's amazing.
After watching Tony Buser's Vimeo instructions on cleaning up a model, I got a even better STL to print now.
I am amazed with ReconstructMe, but at the same time a bit disappointed due to the software loosing track when using the free version. It's sometimes hard to use at all, especially freehand :-(
Still- not bad, especially since I did this freehand scanning myself & only on the regular, not the high resolution...
By the way:
Any experiences with http://www.agisoft.ru/products by the way? Did I understand right, it's a photo based method that is NOT cloud based (as the others are)? For 99 a licence that might be worth considering (have not tried it yet)...
Marcus
Postby ken schmitt » 2012-Nov-Wed-10-Nov
Your details will hold up pretty well on most prints of at least 4 inches, the bigger the better with the default scan.
The truth is the slicing and extrusion just averages out most of what would be fine detail anyhow.
Decimate your objects, you can reduce it by half and it wont change the geometry at all, but make it a much friendlier file.
ken schmitt
Postby Marcus » 2012-Nov-Wed-10-Nov
Indeed, printing is somewhat a smoothing-filter anyway ;-) Though poisson filter really improved the texture. Scanning on hi res results in new problems, the artificial track-loosing of the free version is annoying. Very annoying.
The tutorial also includes that and a file size reduction, though it wasn't too bad. Mesh mixer is a great tool to soften out some bumps and dents :-)
Marcus
Postby duque456 » 2017-Oct-Thu-01-Oct
Hello..
I am looking for 3D scanning services but not found till now so please anyone tell me about this services?
duque456
Postby Mooselake » 2017-Oct-Fri-15-Oct
duque456 wrote:Hello..
Google "3D scanning services in India" without the quotes.
You may be the first time I've seen a 1.x.x.x IP address used. To bad it appears it's for necroposting spam
Return to Off topic talk
