What did you print today?
Postby Mochaboy » 2013-Aug-Tue-00-Aug
I'm working my way backwards, but I wanted to keep a running log of everything everyone's printing - who knows it might be something useful to someone else that didn't even know that part existed :)
I'll start.
http://www.thingiverse.com/thing:38282
I was at a radio controlled FPV meet here in the Northeast just recently and I can honestly say that I spent 3/4 of my time there showing people the printer and the remaining time flying :)
The girl I printed that for reported back later that yes - it is a working shotglass :)
Printrbot Jr born 6/13
Brass M8 Threaded Z Rod
Tool less belt tensioners
Aluminum print plate
Build log & Mods
Mochaboy
Print winner 1st
Print winner 1st
Re: What did you print today?
Postby mrsamnc » 2013-Aug-Tue-05-Aug
Monday, 8/12/2013:
Bowden Extruder Mounts
An extra set of Jr. Bed Levelers
Mochaboy's Tool Less Belt Tensioners - GT2
Needless to say, I'm planning a tear-down and slight overhaul soon. :ugeek:
My Build/Mod Log
mrsamnc
Postby Mochaboy » 2013-Aug-Tue-09-Aug
I spy with my little eye...
Supports/rafts on the bowden mount?
Love to see a build log on that process when you're through it :)
Build log & Mods
Mochaboy
Print winner 1st
Print winner 1st
Postby mrsamnc » 2013-Aug-Tue-11-Aug
Mochaboy wrote:I spy with my little eye...
You're correct sir! :) I wanted them to be as clean and precise as possible.
And yes, I'll most definitely put a build log together with the Bowden. :) I have something special planned for that... A combo "thing" for multiple solutions. ;)
My Build/Mod Log
mrsamnc
Postby mrsamnc » 2013-Aug-Tue-20-Aug
Tuesday, 08/13/2013:
Both are right off printer with only minimal raft-cleaning thus far. I still need to drill out the holes to proper diameter.
Printrbot Jr. Z Axis Improvement
Printrbot Jr. Upper and Lower Filament Guides - Though I'll likely only use the lower guide
My Build/Mod Log
mrsamnc
Postby Lemm » 2013-Aug-Thu-03-Aug
Bowden Extruder Mount printed yesterday.
The upper and lower filament guides are next on my list ;). Did you already mount the lower one ?
Printrbot Jr #11045
ACME TR10x2 Z Rod
Printrbot Jr v1 -> v2 upgrade http://sdrv.ms/15fDDud
Lemm
Postby mrsamnc » 2013-Aug-Thu-04-Aug
Not yet, I'm waiting for my brass M8 rod to come in to do a tear down and upgrade it all at once. Where did you get your Bowden supplies from?
My Build/Mod Log
mrsamnc
Postby Mochaboy » 2013-Aug-Thu-08-Aug
Lemm wrote:Bowden Extruder Mount printed yesterday.
These juniors are like the Borg.
"You will be assimilated. {into my design}"
I need to be a little more thoughtful about the parts I'm making and make sure this thing doesn't end up looking like a junkyard scrapper. Very interested to read your report on the printing capabilities with that setup.
Build log & Mods
Mochaboy
Print winner 1st
Print winner 1st
Postby nepaholic » 2013-Aug-Thu-09-Aug
Printed a pink panther woman today. :)
Soooooo sexy
nepaholic
Postby mrsamnc » 2013-Aug-Thu-09-Aug
Very nice... err... print resolution! :D
My Build/Mod Log
mrsamnc
Postby Mochaboy » 2013-Aug-Thu-10-Aug
re-home Z axis + 100
hubba hubba
Build log & Mods
Mochaboy
Print winner 1st
Print winner 1st
Postby Lemm » 2013-Aug-Thu-11-Aug
Mochaboy wrote:These juniors are like the Borg.
The Y Axis runs smoother than before, but I have tiny filament stripes/threads .. ( I don't know the correct english word ) between gaps on the printbed. But this could also be a filament or temperature problem ...
Printrbot Jr #11045
ACME TR10x2 Z Rod
Lemm
Postby Mochaboy » 2013-Aug-Thu-14-Aug
I've read that's part of the challenge of bowden extruders. Because of the distance between the filament and the teflon tube, the extruder motor has to retract faster and more filament. If it's leaving wisps and strings, it's probably just a few degrees to hot..I'd say drop your temps 3-5 degrees and observe.
Build log & Mods
Mochaboy
Print winner 1st
Print winner 1st
Postby Lemm » 2013-Aug-Thu-14-Aug
yeah I'm running a Lithopane print right now with 190° instead of 200.Looks better I can tell more when it's ready
Printrbot Jr #11045
ACME TR10x2 Z Rod
Lemm
Postby mrsamnc » 2013-Aug-Thu-15-Aug
This was Wednesday's, 08/14/2013, prints:
Bearing bushing/washer combos and some washers for this. Fancy-fancy! ;)
My Build/Mod Log
mrsamnc
Postby mrsamnc » 2013-Aug-Fri-22-Aug
This is one hard print! My attempt at the Bamboo Basket. The catch: NO SUPPORT MATERIAL. I wanted to kill the print a few times because of the horror, but endured. I'm surprised it even turned out recognizable. ;)
Give it a shot, I challenge Thee! :twisted:
My Build/Mod Log
mrsamnc
Postby REPRAP SQUAD » 2013-Aug-Sat-14-Aug
This one would be a good print to test out using disolvable printe material for support on my Printrbot dual extruder beta build. Good prints guys.
http://www.enviousmods.com
Postby Lemm » 2013-Aug-Sun-12-Aug
Printrbot Jr #11045
ACME TR10x2 Z Rod
Lemm
Postby nepaholic » 2013-Aug-Sun-12-Aug
Wow
So awesome
nepaholic
Postby Lemm » 2013-Aug-Tue-15-Aug
The Printrcup a bit modified
Printrbot Jr #11045
ACME TR10x2 Z Rod
Lemm
Postby mrsamnc » 2013-Aug-Tue-15-Aug
Heck yeah! That's great! :) I'm nearly done with my V2 model, but really like what you did with yours. :D
My Build/Mod Log
mrsamnc
Postby Mochaboy » 2013-Aug-Tue-19-Aug
OH F@ that's COOL!
You people are frikkin talented.
Build log & Mods
Mochaboy
Print winner 1st
Print winner 1st
Postby mrsamnc » 2013-Aug-Wed-05-Aug
Garden Gnome at 30% original size. 0.2mm layer height, MatterHackers' Peak Green PLA, 2 hr print time
My Build/Mod Log
mrsamnc
Postby Mochaboy » 2013-Aug-Wed-09-Aug
I love that gnome.
What's up with the banding? Your prints are always glass smooth up the faces.
Build log & Mods
Mochaboy
Print winner 1st
Print winner 1st
Postby mrsamnc » 2013-Aug-Wed-12-Aug
Man, I don't know... :| I don't know if the Z Axis Stiffiner I added is putting excess tension on the bot, or what... I've not changed my Z Axis rod yet (still waiting on it to arrive, after 15 days), so it's not that... Between this and the "out of square" print problem I'm having, I'm getting a little discouraged with the bot. In the back of my mind the woodworker in me keeps talking about wood movements with humidity/temperature and how that wouldn't be a great idea for a precision instrument's structural pieces. But the optimist in me says "But hey, other people have the Jr. and are getting good results, so it's probably not the wood." :? :roll: Maybe when my M8 rod finally arrives, I'll take a week or two to do a complete tear-down of the bot and fabricate some of the wood pieces out of aluminum.
Here's another photo of the Gnome with some objects for size-comparison.
My Build/Mod Log
mrsamnc
Postby Mochaboy » 2013-Aug-Wed-16-Aug
don't be dissin junior!!!
.30 layer height
60mm/s speed across the board except 1st layer 30mm
200/190 on MakerGeek nuclear green PLA
Aluminum Printbed was at about 50c
On a side note - you wouldn't believe what I just tried to use as a surface finish...
So there I was - 3am in the morning, couldn't sleep...I decide to take apart some 1.2ghz receivers and solder extensions into the port to hook up a 5.8 transmitter to it. My base station operates at 5.8ghz so doing so allowed me to receive a video signal wirelessly.
Anyway - I go to grab my little bottle of no clean flux, and immediately started cursing at the sticky/tacky lid. It doesn't take a lot, but once you get a little of this flux on a surface, it just doesn't go away until you wipe it away with alchohol.
And then it hit me! Flux is resin, and resin is sticky, flux just happens to be wonderful for high temperature applications where you need something to stick a little, but not TOO much.
This is what I using
Chipquick No Clean Paste Flux
This figure was the proof of concept for that theory. I printed the base layer at 30mm/s completely unattended. Previously I couldn't get it to stick unless it was printing at 5mm and even then it was a struggle. I would have to babysit the first layer with a pair of tweezers and corners always always always came loose (even with the glue stick).
I need to put together video so you can see the difference between clean/heated/resin'd + heat but the "stick factor" was striking. I'm finding that with just enough heat (about 50c), I'm getting awesome adhesion...but only time will tell.
Build log & Mods
Mochaboy
Print winner 1st
Print winner 1st
Postby RetireeJay » 2013-Aug-Wed-17-Aug
Can we get a moderator to move the last two posts to a separate thread for print bed materials and preparation?
Postby Chris Snyder » 2013-Aug-Wed-17-Aug
@Mochaboy
viewtopic.php?f=20&t=4596&p=29967&hilit=true+z+layer#p29967
And I have printed nothing in the last week due to Jr. being down.
Chris Snyder
Postby Mochaboy » 2013-Aug-Wed-17-Aug
Chris...
What's the matter bro? Junior pitching a fit?
Build log & Mods
Mochaboy
Print winner 1st
Print winner 1st
Postby mrsamnc » 2013-Aug-Thu-05-Aug
Repeat of the Gnome. Turned out much better. Here's the deal with the first try
My Build/Mod Log
mrsamnc
Postby Chris Snyder » 2013-Aug-Thu-18-Aug
Oooh, sorry Mochaboy. The comment was for mrsamnc (you get derp when got more than 4 screens up). As for the printer being down...
Don't forget to PM(prevented maintenance) your bot, guys. Tighten those lose nuts, Chapstick that z rod, and Buy Good Filament!
You don't want to be printing dust-bunnies, like I did today.
Chris Snyder
Postby mrsamnc » 2013-Aug-Fri-14-Aug
Fresh off the bot, and likely not the only thing for today. ;)
My Build/Mod Log
mrsamnc
Postby jwatte » 2013-Aug-Sun-15-Aug
Prototypes for robot brackets I will mill in aluminum. And a good thing -- one of them had the wrong circular hole count, so I'll have to fix that! (Would have been a lot more annoying to find out after I had cut it from aluminum...)
I design these in Inventor, so they're not on Thingiverse. That being said -- Inventor exports perfectly fine STLs with no intersecting triangles or bad normals or open shapes, which is more than you can say for pretty much all Thingiverse objects.
jwatte
Postby rho-wan » 2013-Aug-Sun-17-Aug
Partially offtopic: could you briefly summarize the differences between AutoCAD vs Inventor and, if know them, SolidEdge (free for students) and Solidworks?
rho-wan
Postby jwatte » 2013-Aug-Sun-18-Aug
I've only used AutoCad a little bit. AutoCad is at the core a 2D program. Inventor is at the core a 3D program. Inventor lets you easily take many parts and assemble them into mechanical assemblies (with joints/degrees of freedom) that you can simulate for various parameters (wear, load, etc.)
Inventor also has nice interop with 3ds Max and Maya, if you're into the "sculpting" part of 3D.
I don't know the other two programs. Online, the difference between Inventor and SolidWorks seems to be like the difference between Ford and Chevy -- I'm sure either will get the job done, for almost any value of "the job" :-)
jwatte
Postby mrsamnc » 2013-Aug-Sun-19-Aug
My Build/Mod Log
mrsamnc
Postby rho-wan » 2013-Aug-Mon-01-Aug
jwatte wrote:I've only used AutoCad a little bit. AutoCad is at the core a 2D program. Inventor is at the core a 3D program. Inventor lets you easily take many parts and assemble them into mechanical assemblies (with joints/degrees of freedom) that you can simulate for various parameters (wear, load, etc.)
I tried Blender too, but that one does everything with meshes… there is no "intersection of circle and line", you have to approximate the circle with segments and then place correctly one node on the intersection.
It's free and actually easy, but losing the original primitive and going to the approximation immediately seems not a good idea. I start later a thread to gather opinions from people using multiple softwares.
rho-wan
Postby Lemm » 2013-Aug-Mon-11-Aug
Printrbot Jr #11045
ACME TR10x2 Z Rod
Lemm
Postby mrsamnc » 2013-Aug-Mon-16-Aug
Cool fish! Is that your design? Any chance for an STL? :D
My Build/Mod Log
mrsamnc
Postby Chris Snyder » 2013-Aug-Mon-16-Aug
@roh-wah
I own a copy of Solid Edge st2 (used st3, 4, and 5) and have used Solidworks (maybe) 2010. Aside from the user interface and the ready .stl support of SW, there is little diffrance from the two. Why. 3ds(solidworks) uses Siemens' (soldedge) kernel from SE. The logic and concept of out results are very close. Or, another way of looking at it is, I do this and that happens in SE, I do this in SW and the same thing happens as it would in SE, I try to do this in AutoDesk Inventor 2013 and that does not happen at all like SW or SE.
My two pennies, AutoDesk Inventor has a better work flow.
Chris Snyder
Postby mrsamnc » 2013-Aug-Mon-20-Aug
I liked the Angry Fish Clip so I made one too. Neat little print! :)
My Build/Mod Log
mrsamnc
Postby Lemm » 2013-Aug-Tue-01-Aug
mrsamnc wrote:Cool fish! Is that your design? Any chance for an STL? :D
Sorry I forgot to share the thingilink http://www.thingiverse.com/thing:135730 :oops:
Do you use brim for your prints ?
Printrbot Jr #11045
ACME TR10x2 Z Rod
Lemm
Postby mrsamnc » 2013-Aug-Tue-04-Aug
Yes. I have been printing brims on everything lately to prevent warping.
My Build/Mod Log
mrsamnc
MakerBot Gnome
Very pleased with the outcome. :) I can tell the M8 has made a difference in quality.
0.2mm layer height
2 perimeters
10% infill
no support material
no brim
2 1/2 hr print time - unattended print
  • 2
My Build/Mod Log
mrsamnc
Postby AlexC » 2013-Aug-Thu-23-Aug
http://www.thingiverse.com/thing:84075
An experiment to see what would happen, i tried printing this one a few weeks ago at 50% and all i got was a blob,. after the recent upgrades iv done i wanted to re-try,. ill need to clean it up a bit along the edges,. but considering all the pedals are 1 wall thick,.. and there is a ton of retracts & wipes, not bad,.
  • 3
AlexC - Printbot LC v2, TazBot, Phoenix 1, & Prusa i3
Currently building a Kossel.
http://www.thingiverse.com/AlexCphoto/
AlexC
Postby Mochaboy » 2013-Aug-Thu-23-Aug
AlexC wrote:http://www.thingiverse.com/thing:84075
Pink panther lady next please
: D
Build log & Mods
Mochaboy
Print winner 1st
Print winner 1st
Postby mrsamnc » 2013-Aug-Fri-04-Aug
Very nice AlexC! :)
My Build/Mod Log
mrsamnc
Postby mrsamnc » 2013-Sep-Fri-07-Sep
Random Vase - I chose the "thick wall" file to print out for a pen cup at work. 0.4mm layer height (wasn't concerned about ultra-fine resolution). Works great as a pen cup and also serves as a conversation piece for 3d printing. :)
My Build/Mod Log
mrsamnc
Postby hugerobots » 2013-Sep-Sat-14-Sep
IN MOTHER CANADA, BEER DRINKS YOU
hugerobots
Postby rho-wan » 2013-Sep-Sat-14-Sep
I printed a modification for the dust bin of the Vorwerk VR100, that usually become loose and prevents the completion of the cleaning:
https://www.dropbox.com/sh/wia3c00vwe28ncy/TrE7LJmnzX
rho-wan
Postby Mochaboy » 2013-Sep-Sat-19-Sep
I bought the best screwdriver set money could buy at Harbor Freight (tongue slightly in cheek there)...but I didn't like the blow molded case. Specifically having to pluck them out of those compression slots. I'm a big fan of vertical tool holders like mramnc's creations so I set out to build a tool tray to hold the 30 + bits.
If you haven't seen this already - http://www.harborfreight.com/33-piece-p ... 93916.html
If I'd have replicated that set in the Wiha equivalents, that would have set me back about $200...this set cost $8 and even if I strip a bit, for the cost of 2 wiha bits, I could buy another set of 33.
I went back and forth on the number of bit holders, and after using it for a while, I'm going to rework it so that it has more trays for screws, and fewer holes for bits. I'm very happy with it though :)
Build log & Mods
Mochaboy
Print winner 1st
Print winner 1st
Postby REPRAP SQUAD » 2013-Sep-Sun-11-Sep
They have a super nice multimeter at harbor freight on sale for 20 bucks plus an extra 25% off makes it 15 bucks and it also reads temperature. Im heading down to get one asap as well as print me some good add ons for it.
Postby Mochaboy » 2013-Sep-Mon-12-Sep
I'm tempted to spring on that - it looks like it has a capacitance meter. Nice find.
Build log & Mods
Mochaboy
Print winner 1st
Print winner 1st
Postby Lemm » 2013-Sep-Wed-15-Sep
My longest print 7.5 hours. Scaled to 75%
http://www.thingiverse.com/thing:116288
Printrbot Jr #11045
ACME TR10x2 Z Rod
Lemm
Postby Mochaboy » 2013-Sep-Fri-09-Sep
The talent and ingenuity of these model designers astounds me...that thing is soo cool :)
Build log & Mods
Mochaboy
Print winner 1st
Print winner 1st
Postby Lemm » 2013-Sep-Fri-11-Sep
yeah :D I hope the birds like it too ;)
Printrbot Jr #11045
ACME TR10x2 Z Rod
Lemm
Postby mikemwa53 » 2013-Sep-Sun-06-Sep
I have a bunch of Li-Po batteries. I decided to make a dispenser for them.
It works pretty good although I need to make the ledges a little longer. It holds 20 batteries and this way I can keep them rotated. I had to do it in 4 pieces. Next I am going to make some for my AA and AAA batteries.
Sooooo much to do
Sooooo Little time!!!
Montgomery, IL. USA
mikemwa53
Postby Lemm » 2013-Sep-Sun-06-Sep
cool thing. would u share it ?
Printrbot Jr #11045
ACME TR10x2 Z Rod
Lemm
Postby mikemwa53 » 2013-Sep-Sun-07-Sep
Sure. No problem. As soon as I get it modified a bit I will post it.
Sooooo much to do
Montgomery, IL. USA
mikemwa53
Postby Lemm » 2013-Sep-Tue-00-Sep
Printrbot Jr #11045
ACME TR10x2 Z Rod
Lemm
Postby Mochaboy » 2013-Sep-Wed-11-Sep
Solid work Lemm...
I just printed off a go pro style compression bracket for my usb microscope. This will attach to the boom arm of my Amscope stereo microscope so I can video record my soldering sessions.
The equivalent usb microscope from Amscope is almost the cost of a new microscope...I bought a 3D printer so I could unlock the potential of the piles of crap I already have, so this will mount off the boom arm and be able to swing and adjust the angle :)
Build log & Mods
Mochaboy
Print winner 1st
Print winner 1st
Postby Mochaboy » 2013-Sep-Wed-17-Sep
kewl it works - just have to iron out a few issues and I can post that for download :)
I can finally do proper video recordings of my soldering sessions.
Build log & Mods
Mochaboy
Print winner 1st
Print winner 1st
Postby Lemm » 2013-Sep-Fri-13-Sep
Everybody likes Nescafe or not ? :D
http://www.thingiverse.com/thing:153745
Printrbot Jr #11045
ACME TR10x2 Z Rod
Lemm
Postby Mochaboy » 2013-Sep-Fri-13-Sep
Oh man those are awesome - I'm so printing those off...
Build log & Mods
Mochaboy
Print winner 1st
Print winner 1st
I'm just working on a handle for it
Printrbot Jr #11045
ACME TR10x2 Z Rod
Lemm
Postby drmatrix » 2013-Sep-Mon-20-Sep
Being a Harry Potter fan - the Spine from Thingiverse
http://www.thingiverse.com/thing:27560
Prints in 6 pieces at about 3 - 4 hours each piece and then assembled w/ABS glue - I used white ABS that I got from one of the filament sales here at PrintrBot.
Had a lot of fun and frustration but is now added to our Harry Potter themed bathroom (everybody has one? right?). Goes well w/the wands, cloaks, ties, scarfs, Quaffle (not sure how to spell will have to look up and fix later), etc.
Walker
"the plastic must flow"
drmatrix
Postby Mochaboy » 2013-Sep-Mon-21-Sep
Filthy muggles...
cool bathroom!!! :D
Build log & Mods
Mochaboy
Print winner 1st
Print winner 1st
Postby Lemm » 2013-Sep-Wed-13-Sep
Printrbot Jr #11045
ACME TR10x2 Z Rod
Lemm
Postby hugerobots » 2013-Sep-Thu-02-Sep
  • 2
hugerobots
Postby Mochaboy » 2013-Oct-Fri-09-Oct
Designing is HARD
but so damn rewarding
http://www.thingiverse.com/thing:159726
Build log & Mods
Mochaboy
Print winner 1st
Print winner 1st
Postby Lemm » 2013-Oct-Tue-13-Oct
good idea. I wanted to created something in that way for the pi cam
Printrbot Jr #11045
ACME TR10x2 Z Rod
Lemm
http://www.thingiverse.com/thing:162673
http://www.thingiverse.com/make:49759
Printrbot Jr #11045
ACME TR10x2 Z Rod
Lemm
Postby opiesche » 2013-Oct-Mon-03-Oct
Tiny Planetary gears (http://www.thingiverse.com/thing:23030) in Monoprice's red PLA:
I've scaled it up to 130% (so they're only small, not tiny ;) because I had trouble with the skinny pegs of the lower part of the reducer stage, that push fit into the upper part, breaking off. I then also printed them at 0.15mm layer height, which made for much sturdier pegs than 0.3mm. After a bit of squeezing and audible creaking while turning, it now runs quite smoothly :)
BTW, the monoprice PLA gets an OK rating from me. The red is really translucent and looks orange-ish under normal light. The consistency is so-so (1.68-1.76mm), and it does tend to ooze and string a bit for me (195 degrees), in addition to a bit of warping of the cooled parts. So far, I like Matterhackers' filament better.
opiesche
Postby MSEIF » 2013-Nov-Fri-06-Nov
mrsamnc wrote:Garden Gnome at 30% original size. 0.2mm layer height, MatterHackers' Peak Green PLA, 2 hr print time
I've just fallen in love with these pics. These are awesome dude!
Best Web Design Service in Norwich, UK
Norwich Web Design
MSEIF
Postby Lemm » 2013-Nov-Sun-13-Nov
http://www.thingiverse.com/thing:39466
http://www.thingiverse.com/thing:179106
Printrbot Jr #11045
ACME TR10x2 Z Rod
Lemm
Postby Mochaboy » 2013-Nov-Sat-20-Nov
I do a lot of instructional videos and have a high definition camcorder that I use. Using a tripod on a desk for macro recording is extremely difficult to do, so I worked out a solution where I have a wall mount LCD, and hook up the HDMI port of the camera to the LCD - instant microscope (though I use my microscope too).
Anyway - the camera needed to be mounted on a boom arm so I could push it didn't interfere with both of my hands as I was working - and now I have it :)
Build log & Mods
Mochaboy
Print winner 1st
Print winner 1st
Postby jwatte » 2013-Nov-Sat-23-Nov
Breech/feeder assemblies for airsoft guns for Mech Warfare.
The large cylinder (magazine) is aluminum, as is the barrel; the white/transparent part is a spare part gearbox, and the rest of the black are 3D printed parts from a Printrbot Simple kit.
Two of these will go on my walking robot:
http://www.youtube.com/watch?v=48o1sG8M7Q0
jwatte
Postby Lemm » 2013-Nov-Sun-01-Nov
You have mounted a softgun on a robot?
Printrbot Jr #11045
ACME TR10x2 Z Rod
Lemm
Postby Lemm » 2013-Dec-Tue-04-Dec
http://www.thingiverse.com/thing:205730
Merry XMAS ;)
Printrbot Jr #11045
ACME TR10x2 Z Rod
Lemm
Postby REPRAP SQUAD » 2013-Dec-Tue-11-Dec
That's cool Lemm, merry Christmas to you too!
Postby lisakahl » 2014-Feb-Tue-05-Feb
Nice photos. I printed my photos from my printer.
lisakahl
Postby Lemm » 2014-Mar-Sat-16-Mar
Printrbot fan cover
http://www.thingiverse.com/thing:261115
Printrbot Jr #11045
ACME TR10x2 Z Rod
Lemm
Postby REPRAP SQUAD » 2014-Mar-Sat-16-Mar
Track system for my drag cables on my Printrbot Plus and my new JunkBot Printer that im almost finished with. I also printed out new 40mm fan airplane style intakes with half duct exhaust. They work great on my dual extruder. I was having issues with my upgraded fans effecting hotend temps. Now its not an issue with this new setup. Im also printing custom designed parts for a drag cable setup for the dual extruders on my plus.
Postby ThereWillBprints » 2014-Mar-Sun-00-Mar
Finished the slow print settings with Cura with basic user of my crop circle! Verified I was still within calibration and went on to print tensioner brackets for my simple2014. With that print O kept the the basic user interface but went up in quality to standard as it chucked out 4 new brackets.
All prints were done with starting temperature of 198 and then brought to 195. I also had all speeds for base layers at 70 percent until the twelfth layer. Don't know why but it looked solid. I then put the speeds of everything but walls to 95% while keeping the walls at 92% which was my son's suggestion. A six year old at that :cry:
I use cura on my Mac Mini on Mavericks because it just works. Hopes this helps the Mac users. I simply could not adjust the code for Repetier.
406mm by 8mm lm rods for x and z axis
Z stabilizer bar
bearing plates printed for fabricated plexi glass print bed (8"×18")
New print are a 274 mm width × 267mm height × 101 depth (will change to 200 mm once verified and I have time)
ThereWillBprints
Postby evanalmighty » 2014-Mar-Sun-11-Mar
Took almost a full day, maybe even longer. It's a good thing I don't look to my wife for affirmation because she sure didn't appreciate it at all.
evanalmighty
Postby slicedveggie » 2014-Mar-Sat-11-Mar
evanalmighty wrote:Took almost a full day, maybe even longer. It's a good thing I don't look to my wife for affirmation because she sure didn't appreciate it at all.
Seriously? I cant believe she didnt appreciate it! Im lucky to have a girlfriend that appreciates every hypercube, corgi, test print and minion I print for her. haha.
slicedveggie
Postby plexus » 2014-Mar-Sat-11-Mar
These days I try and not print just for the sake of printing. its a waste of plastic and bad for the environment. since my printers are all nicely tuned up and reliable, I limit my printing to only things I need. today one of my TV tables got on my nerves as its wobbly because one leg is shorter. so i designed and printed this. popped it on the end of the leg and no more wobble.
Postby REPRAP SQUAD » 2014-Mar-Sat-12-Mar
Much agreed Plexus. It would be nice if there was more people that sorted and reused filament.
Postby ThereWillBprints » 2014-Mar-Fri-06-Mar
So I have been down lately due to my own newb abilities, so I fought back with two cool ideas, I hope. It is picture three and placed above where the inside mounting point is located. Looks pretty stealthy for the moment.
Item 1 is a predator emblem keychain from thingiverse. Made it with the clear pla from my simple kit! That is all I have used it for up to this point. Well I also did the Y axis tensioner at the same time. Again this is from thingiverse, but it looked handy.
Before that though I went into full steam upgrade mode with Jon Lawrence's 300mm no sag upgrade. Up until now I had some trouble with my Cura Settings but got it resolved and hopefully will have the motor mount done tomorrow. I am debating if I want to use the sd cards. Never tried yet.
Z stabilizer bar
ThereWillBprints
Postby ThereWillBprints » 2014-Mar-Mon-07-Mar
Thanks to the no sag, mods post I now have this for the simple. Pretty sturdy as well. I will update on how it prints with the new holder. One hour print too for high quality via Cura.
Z stabilizer bar
ThereWillBprints
Postby Stradawhovious » 2014-Apr-Wed-10-Apr
I printed a bunch of these.
http://www.thingiverse.com/thing:11682
Bucky balls are really hard to come by now that the government saw fit to ban them... :roll: But I managed to get me hands on some. Makes for a great office toy.
Stradawhovious
Postby ThereWillBprints » 2014-Apr-Thu-14-Apr
Stradawhovious wrote:I printed a bunch of these.
I really like this!
Z stabilizer bar
ThereWillBprints
Postby REPRAP SQUAD » 2014-Apr-Thu-18-Apr
I needed a new emblem for my side project. Gti vr6 and the used emblem would of cost a ton as they are rare for this setup. So I printed a new front emblem and it worked perfectly the first time around. In the pics I haven't mounted it yet but, it sits where it will go. I decided to make it out of ABS as its the perfect filament for the job. Im in the midst of painting it and then some clear coat.
Postby ThereWillBprints » 2014-Apr-Fri-17-Apr
REPRAP SQUAD wrote:I needed a new emblem for my side project. Gti vr6 and the used emblem would of cost a ton as they are rare for this setup. So I printed a new front emblem and it worked perfectly the first time around. In the pics I haven't mounted it yet but, it sits where it will go. I decided to make it out of ABS as its the perfect filament for the job. Im in the midst of painting it and then some clear coat.
So did you print it with plugs? I have been considering of emblem change ups as well
Z stabilizer bar
ThereWillBprints
Postby REPRAP SQUAD » 2014-Apr-Fri-18-Apr
No I didn't print it with plugs because it has a full projekts two body kit that doesn't use the same mounting setup as the stock grill.
Postby REPRAP SQUAD » 2014-Apr-Sat-21-Apr
I printed a bunch of new parts for my aluminum plus v2. Over the last week its been non stop design and print.
Postby Glook » 2014-May-Mon-02-May
nice printer !!!
today, i print :
http://www.thingiverse.com/thing:217299
Printrbot Simple 2014
GT2 belt
X-Axis extended
Y-Axis no sag
Z-Axis M6
Glook
Postby bleeps » 2014-May-Tue-16-May
Glook wrote:nice printer !!!
today, i print :
What did you slice that with? I tried it with Slic3r and it wouldn't generate enough support to print the torso.
bleeps
Postby REPRAP SQUAD » 2014-May-Thu-14-May
today, i print :
Thanks Glook, I appreciate it. Once I finish the y axis, I have to tear it completely apart to etch it and prep it for paint. It still has quite a few parts that need to be printed.
Postby Glook » 2014-May-Thu-23-May
bleeps wrote:What did you slice that with? I tried it with Slic3r and it wouldn't generate enough support to print the torso.
i have print with Cura, i wil have another try, on this thing soon, and i'll write settings (for the moment, my Simple is out of service... :? i modding it with M6 Z-Axis mod)
GT2 belt
X-Axis extended
Y-Axis no sag
Z-Axis M6
Glook
Next
Return to Things talk
