pop pop boat
pop pop boat
Postby MartyS » 2015-Aug-Tue-00-Aug
After seeing a pop pop boat on thingiverse I needed to at least try and design one myself.
This is what I've come up with so far, going to see if I can simply pressure fit 2 rings together to hold the aluminum foil.
Question will be are the tubes going to be air tight enough for it to work? And of course will it work printed in PLA?
MartyS
pop pop boat
Re: pop pop boat
Postby thawkins » 2015-Aug-Wed-23-Aug
seiha wrote::D :D :D :D :D :D :D :D :D :D :D
Thai spam content removed
Non english posts outside of the desigmated regional forumns will be removed
Reason: Don't know Thai, can't remove business name reference
Re: pop pop boat
Postby MartyS » 2015-Aug-Thu-00-Aug
I'm assuming that post is a "like", considering all the smiles, but I'm not going to try and run the text through a translator.
Thought I posted this earlier but I guess it never showed up, weird.
I printed partial pieces to run some tests.
The pressure ring worked to make a water tight seal with the aluminum foil when cold, but PLA softens too much at boiling temperature so it started leaking.
So I'll have to do some redesign and use silicon glue. Got some other ideas also, going to drop down to the standard 2 tube design after doing a little more research, most of the boilers with more than 2 use more than just a tea candle so they must need more heat. Good news is my printed tubes seem to be air tight enough, so they should work.
MartyS
Re: pop pop boat
Postby frankv » 2015-Aug-Thu-01-Aug
MartyS wrote:I'm assuming that post is a "like", considering all the smiles, but I'm not going to try and run the text through a translator.
Google Translate tells me...
Online Casino In the latest styles from <name deleted> Casino Resort.
Ban him!
Reason: Removed spamming business name
Re: pop pop boat
Postby Mooselake » 2015-Aug-Thu-05-Aug
The post was from a known spam IP in Cambodia, advertising an online casino. Since I don't know Thai I can't x out the business name, so I banned the spammer and removed the offending content from Tim's post (sorry...).
This might be our first spam from Cambodia; we're gaining world attention!
Re: pop pop boat
Postby cacb » 2015-Aug-Thu-10-Aug
Mooselake wrote:The post was from a known spam IP in Cambodia, advertising an online casino. Since I don't know Thai I can't x out the business name, so I banned the spammer and removed the offending content from Tim's post (sorry...).
Thai and Khmer (Cambodia) are totally different languages, not even in the same groups of languages. Being fluent in Thai would be of no assistance....
cacb
Re: pop pop boat
Postby Mooselake » 2015-Aug-Thu-18-Aug
cacb wrote:Thai and Khmer (Cambodia) are totally different languages, not even in the same groups of languages. Being fluent in Thai would be of no assistance....
Google translate identified the language as Thai (I'll take it's word for that...), but the posting IP was in Cambodia per a whois. Stopforumspam.com had multiple complaints on spam originating from that IP address and also identified it as Cambodian.
Thai from Cambodia isn't really any stranger than English language spam originating in Pakistan or India, which are pretty common. Although it is kinda strange that my oldest was in both Cambodia and Thailand earlier this year :)
Return to Things talk
