Hi, I just repaired my new Printrbot Metal Simple Kit with replacement bearings and rod (and also PC power supply) from Printrbot as the first version of assembly jammed completely because of rough bearings (see with 3Dbenchy distorted before repair and disassembly).
So, I am on the start line again – and my first prints with rebuilded kit looks… Different. (Picture.)
Question for advanced Printrbot users: There is bunch of problems, like the 1st layers with corners rounded up even on raft(!), some solid walls are distorted, surface is not without small random slopes… Do you see something already resolved by you after callibrating new machines? Thank you for tips in advance.
PS: Yes, fan shroud is functional.
