by carlos » 2015-May-Wed-11-May
Thanks for the tips and it was quite helpful. Glad to report that the fan shroud was unharmed.
Thankfully the fillament just squeezed it's way up and out, but I think it was due to the heat shroud protecting and keeping things in place
The heat shround is now completely solid, not sure if I can save and reuse it.
I heated the hotend to about 120 and that helped melt some of the filament. Slowing clipping away with wirecutters making sure to be super careful around the wires.
I removed a pretty good amount and was able to wipe most of it off using a flat edge to get inbetwwen the grooves.
The culprit of this ill-fated clog i'm thinking is due to the base layers corners lifting off the bed. The hot end caught a raised corner and probably dislodged the print off the bed.
You can see some warping on the bottom, I guess I might have to do a little more calibration.
Is there a recommendation for the heat shroud, not so sure it's worth paying $10 just to replace it.
Also I wasn't sure if that was white teflon tape. I'd like to replace it, but wanted to make sure if anyone can confirm exactly what is used.
Thanks you all again for the tips, so far so good.
Cheers!
Printrbot Simple Metal (using Rev F board) with E3D hot-end and heated bed.
